Full Version: popup/plugin that tells you where films are located
Hi all, i would like to know (and sorry if there's another open 3rd about this feature suggestion) if there's an existing plugin that tells you to connect a certain HD where is located your film when you want to watch it. I have a lot of Hard drives full of movies/tv series (i think i'm not the only one Tongue ), instead of rename it all with at the beginning the suffix hd1,hd2,hd3 ecc.. (like i've made it until now) is there maybe a solution for this? maybe a popup that comes out when you click on your wanted film.
Sorry for the poor english.
p.s. Thanks very much if someone can help me maybe just redirecting me where i can find solutions.
regards, stefano
if you hit the info button on any movie in the library it should tell you what the file path is.
I'm not sure how obvious it is on other skins but I use transparency and the file path is quite easy to find in one click
What Justcop said. Also maybe this solution could be interesting for you (no need to press info): http://forum.xbmc.org/showthread.php?tid=96183
