Full Version: Harmony 550 Key Presses
I have configured my harmony 550 as an mceusb remote. I used irrecord to capture the codes. Everything works, sort of. I have to press what ever key I want to use twice. Apparently either I don't know how to search for this problem, or it isn't common as I found only one post anywhere. I have messed with gap, down to 12345 and up to 200000. I have gone to the harmony config and used 0-5, all to no avail. Any help would be appreciated. Thanks.
Edit: I am running ubuntu 10.04 and xbmc 10.0
What IR receiver are you using? Apparently Logitech Harmony remotes can be picky... Sad
I am using the soundgraph imon (LCD) that came with the antec 430. I haven't tried it with anything in ubuntu, though. Thanks.
