2011-03-07, 17:05
Hello all:
I just did a recent brand new install and it seems as though some files I am playing are causing tearing issues with DXVA2 enabled.
System is a very basic one:
Asus P755H-M Pro Motherboard
Intel i3 540 Clarkdale CPU
(HD is handled by onboard GPU)
Win 7 64-Bit Ultimate
Running Dharma 10.0, some files will give that macroblocking/tearing/green screen issue. If I disable DVXA2 in the settings, the problems go away.
Is this a know issue and is there a fix to this? I can play the files perfectly fine in MPC-HC.
I should add that my install has been a fresh install (done Friday) so I haven't the simplest reason why this is happening. Most files play fine but a select few are doing this.
Here's the Media Info from one file:
Quote:Format : Matroska
File size : 6.54 GiB
Duration : 1h 48mn
Overall bit rate : 8 655 Kbps
Encoded date : UTC 2011-03-01 14:38:35
Writing application : mkvmerge v3.2.0 ('Beginnings') Feb 12 2010 16:46:17
Writing library : libebml v0.7.9 + libmatroska v0.8.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 12 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 48mn
Bit rate : 7 141 Kbps
Width : 1 280 pixels
Height : 534 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.436
Stream size : 5.27 GiB (81%)
Title : (deleted)
Writing library : x264 core 114 r1913 5fd3dce
Encoding settings : cabac=1 / ref=12 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.10:0.10 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=2 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=7141 / ratetol=1.0 / qcomp=0.60 / qpmin=1 / qpmax=63 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / nal_hrd=none / ip_ratio=1.40 / aq=1:0.80
Language : English
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 48mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.14 GiB (17%)
Title : DTS 5.1 1510kbps
Language : English
