Full Version: Crash while trying to play mpg, mp4, flv
While trying to play mpg, mp4, flv xbmc crashes. Crash log is here:
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Cum Şub 25 20:02:53 EET 2011
XBMC Options:
Arch: x86_64
Kernel: Linux 2.6.37 #1 SMP Mon Jan 17 09:39:16 EET 2011
Release:
LSB Version: n/a
Distributor ID: Pardus
Description: Pardus 2011
Release: 2011
Codename: n/a
############## END SYSTEM INFO ##############
############### STACK TRACE #################
############# END STACK TRACE ###############
################# LOG FILE ##################
20:02:39 T:140271066687584 M:3273351168 NOTICE: -----------------------------------------------------------------------
20:02:39 T:140271066687584 M:3273326592 NOTICE: Starting XBMC, Platform: Linux (Pardus 2011, 2.6.37 x86_64). Built on Feb 4 2011 (SVN:Unknown)
20:02:39 T:140271066687584 M:3273326592 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
20:02:39 T:140271066687584 M:3273326592 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
20:02:39 T:140271066687584 M:3273326592 NOTICE: special://masterprofile/ is mapped to: /home/mustafa/.xbmc/userdata
20:02:39 T:140271066687584 M:3273326592 NOTICE: special://home/ is mapped to: /home/mustafa/.xbmc
20:02:39 T:140271066687584 M:3273326592 NOTICE: special://temp/ is mapped to: /home/mustafa/.xbmc/temp
20:02:39 T:140271066687584 M:3273326592 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
20:02:39 T:140271066687584 M:3273326592 NOTICE: Log File is located: /home/mustafa/.xbmc/temp/xbmc.log
20:02:39 T:140271066687584 M:3273326592 NOTICE: -----------------------------------------------------------------------
20:02:39 T:140271066687584 M:3273351168 NOTICE: Setup SDL
20:02:39 T:140271066687584 M:3272953856 NOTICE: load settings...
20:02:39 T:140271066687584 M:3272851456 NOTICE: special://profile/ is mapped to: special://masterprofile/
20:02:39 T:140271066687584 M:3272851456 NOTICE: loading special://masterprofile/guisettings.xml
20:02:39 T:140271066687584 M:3272597504 NOTICE: Getting hardware information now...
20:02:39 T:140271066687584 M:3272597504 NOTICE: Checking resolution 12
18:02:39 T:140271066687584 M:3272597504 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:02:39 T:140271066687584 M:3272597504 NOTICE: Loaded playercorefactory configuration
18:02:39 T:140271066687584 M:3272597504 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
18:02:39 T:140271066687584 M:3272597504 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:02:39 T:140271066687584 M:3272597504 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
18:02:39 T:140271066687584 M:3272597504 NOTICE: Default DVD Player: dvdplayer
18:02:39 T:140271066687584 M:3272597504 NOTICE: Default Video Player: dvdplayer
18:02:39 T:140271066687584 M:3272597504 NOTICE: Default Audio Player: paplayer
18:02:39 T:140271066687584 M:3272597504 NOTICE: Loading media sources from special://masterprofile/sources.xml
18:02:40 T:140271066687584 M:3208355840 NOTICE: Using visual 0x4f
18:02:40 T:140271066687584 M:3206213632 NOTICE: GL_VENDOR = NVIDIA Corporation
18:02:40 T:140271066687584 M:3206213632 NOTICE: GL_RENDERER = GeForce 6200 LE/PCI/SSE2
18:02:40 T:140271066687584 M:3206213632 NOTICE: GL_VERSION = 2.1.2 NVIDIA 260.19.29
18:02:40 T:140271066687584 M:3206213632 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20 NVIDIA via Cg compiler
18:02:40 T:140271066687584 M:3206213632 NOTICE: GL_EXTENSIONS = GL_ARB_color_buffer_float GL_ARB_copy_buffer GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_ES2_compatibility GL_ARB_explicit_attrib_location GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_sampler_objects GL_ARB_separate_shader_objects GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_swizzle GL_ARB_timer_query GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_gpu_program_parameters GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_sRGB GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_copy_depth_to_color GL_NV_depth_clamp GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
18:02:40 T:140271066687584 M:3206197248 ERROR: GLX: Same window as before, refreshing context
18:02:40 T:140271066687584 M:3201404928 NOTICE: start dvd mediatype detection
18:02:40 T:140271066687584 M:3201404928 NOTICE: initializing playlistplayer
18:02:40 T:140271066687584 M:3201404928 NOTICE: DONE initializing playlistplayer
18:02:40 T:140271066687584 M:3194015744 NOTICE: initialize done
18:02:40 T:140271066687584 M:3194015744 NOTICE: Running the application...
18:02:40 T:140271066687584 M:3194015744 NOTICE: ES: Starting event server
18:02:40 T:140271066687584 M:3194015744 NOTICE: DS: Starting dbus server
18:02:40 T:140270675359504 M:3194015744 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
18:02:40 T:140270675359504 M:3193872384 NOTICE: UDP: Listening on port 9777
18:02:40 T:140270650308368 M:3193872384 NOTICE: DS: Starting DBUS server in Run Application aka thread
18:02:40 T:140271066687584 M:3193745408 NOTICE: starting zeroconf publishing
18:02:53 T:140271066687584 M:3185090560 NOTICE: DVDPlayer: Opening: /home/mustafa/Videolar/Jesse McCartney - Shake.mp4
18:02:53 T:140271066687584 M:3185090560 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
18:02:53 T:140270467065616 M:3185090560 NOTICE: Creating InputStream
18:02:53 T:140270467065616 M:3185090560 NOTICE: Creating Demuxer
18:02:53 T:140270467065616 M:3177852928 NOTICE: Opening video stream: 0 source: 256
18:02:53 T:140270467065616 M:3177852928 NOTICE: Creating video codec with codec id: 28
18:02:53 T:140270467065616 M:3177852928 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
18:02:53 T:140270467065616 M:3177852928 NOTICE: Creating video thread
18:02:53 T:140270467065616 M:3177852928 NOTICE: Opening audio stream: 1 source: 256
18:02:53 T:140270467065616 M:3177852928 NOTICE: Finding audio codec for: 86018
18:02:53 T:140270467065616 M:3177852928 NOTICE: Creating audio thread
18:02:53 T:140270417721104 M:3177836544 NOTICE: running thread: CDVDPlayerAudio::Process()
18:02:53 T:140270417721104 M:3177836544 NOTICE: Creating audio device with codec id: 86018, channels: 2, sample rate: 44100, no pass-through
18:02:53 T:140270426113808 M:3177832448 NOTICE: running thread: video_thread
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
mustafa@pardus2011 ~ $ xbmc
params.c:OpenConfFile() - Unable to open configuration file "/home/mustafa/.smb/smb.conf":
No such file or directory
params.c:OpenConfFile() - Unable to open configuration file "/home/mustafa/.smb/smb.conf.append":
libva: libva version 0.31.1-sds1
libva: va_getDriverName() returns 0
libva: Trying to open /usr/lib/va/drivers/nvidia_drv_video.so
xbmc.bin: vdpau_driver.c:233: vdpau_do_Initialize: Sav `vdp_status == VDP_STATUS_OK' failed.
/usr/bin/xbmc: line 133: 3629 Cancelled "$LIBDIR/xbmc/xbmc.bin" $SAVED_ARGS
Crash report available at /home/mustafa/xbmc_crashlog-20110225_203447.log
What can be the problem?
