Full Version: ListItem.Label2
Hi guys,
is there a way to make ListItem.Label2 display duration in shorter way - i.e. 90 minutes instead of 01:30:15?
Just use ListItem.Duration.
Hitcher Wrote:Just use ListItem.Duration.
I'm using ListItem.Duration in info panel but have .Label2 in Container "50". It's mostly working OK, so I wanted to keep it and stick with build in solution where ever possible - biggest problem is with movie duration.
I'll try to solve it using some check. String compare with Control 3 get label somehow, I suppose.
