2011-03-10, 04:55
2011-03-10, 05:25
Below link is for a solution from Amet (prevent iOS update) which was posted this past February. Note that I already had the mesu.apple.com server resolved to 127.0.0.1, yet still received update prompts. Below appears to have solved the issue.
http://forum.xbmc.org/showthread.php?tid=93604
2011-03-10, 05:53
Yup apple is on the move. Had the same problem. Not sure if it was the extra line in hosts or saying I would upgrade later
2011-03-10, 06:37
You're welcome guys
BTW, According to the thread linked above from Eric_S, the hosts file should end out something like this instead:
(Extra lines provided by amet)
Hope this works
I've had no problems with mesu.apple.com rerouting to localhost, but you can never guess
BTW, remember to save your SHSH's using TinyUmbrella
(Disconnect ATV2 from tv, etc, Plug to wall the device, wait for 20 sec -leave it plugged to wall- and plug the device to USB, Tinyumbrella recognizes the device, just Press Save SHSH button on top right side of window)
Cheers!
# Host Database
# localhost is used to configure the loopback interface
# when the system is booting. Do not change this entry.
127.0.0.1 localhost
255.255.255.255 broadcasthost
::1 localhost
fe80::1%lo0 localhost
127.0.0.1 appldnld.apple.com
127.0.0.1 mesu.apple.com
127.0.0.1 appldnld.apple.com.edgesuite.net[PRESS ENTER HERE]
[LEAVE THIS LINE EMPTY | DELETE LINE]
Hope this works
Cheers!
2011-03-10, 08:00
Can some one help me in how to ping.. Sorry NOOB Here... lol
2011-03-10, 11:55
Thank you
yllus Wrote:It's located at /etc/hosts .
2011-03-10, 12:44
Thanks vtwin0001, work fine
2011-03-10, 13:07
Install the package "updatebegone" !
apt-get install com.nito.updatebegone
2011-03-10, 14:10
DarkVamp Wrote:Install the package "updatebegone" !I installed apt-get install com.nito.updatebegone. Now I am going to test to see if it works well.
2011-03-10, 14:13
dejanco Wrote:I installed apt-get install com.nito.updatebegone. Now I am going to test to see if it works well.
Please report back
2011-03-10, 14:44
Hi all..
Tried to do this but got the following error message:
E: Could not open lock file /var/lib/dpkg/lock - open (2: No such file or directory)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
What to do? Do i have to restore? And how do i restore without updating to the new Ios?
Thanks in advance for any help...
2011-03-10, 16:22
jisel Wrote:Hi all..
try:
sudo apt-get install com.nito.updatebegone
2011-03-10, 18:31
DarkVamp Wrote:try:
Not working...
Hmm, any ideas of how i restore my atv without upgrading to the new ios?
I think the installation of xmbc corrupted something, as i was able to install it through nito, but now i can't install anything there....
2011-03-10, 20:49
DarkVamp Wrote:Install the package "updatebegone" !Thanks... Just ran this now, see what happens
2011-03-10, 21:00
XBMC is running fine since two hours with updatebegone. My girl told me that it stopped working this morning every 3-4 minutes so i was glad to see a fix immedialty when i got home from work
@jisel: Should be no problem when you saved your shsh blobs. Just start TinyUmbrella's TSS Server and restore with iTunes.
