I dl'ed Rapier, unzipped it. But where to install it?? I tried /~/Library/Application Support/Xbmc/addons, restarted the Mini but no luck.
Are you using Dharma?
Rapier is not Dharma compatible. You can look at the topics for either rapier MikotoBuild or qualarmod for Dharma compatible mods. For either you can use a manual zip install, or for MikotoBuild you can use the passions-XBMC repository linked on the thread.
If you aren't using Dharma... you really should be.
Matteius Wrote:If you aren't using Dharma... you really should be.
I am using OSX 10.6.6 and want to remain using that.
OSX is your operating system... Dharma is the build of xbmc
