2011-03-10, 04:36
Hello,
I'm experiencing a strange behaviour when using the FixedList control. In some instances, when you reach the last item in the list, you come to the end and then you must go the opposite way to get to the first item; however, in many other instances, i get to the last item but it then moves to the first item.
If this makes sense, is there a reason for this behaviour? Below is partial code that is used, the only thing that changes is the visibility condition:
PHP Code:
<control type="fixedlist" id="51">
<description>Home Wraplist</description>
<posx>-220</posx>
<posy>232</posy>
<width>1500</width>
<height>361</height>
<visible>Container(300).HasFocus(1)</visible>
<onup>300</onup>
<ondown>300</ondown>
<focusposition>1</focusposition>
<scrolltime>300</scrolltime>
<viewtype>list</viewtype>
<orientation>horizontal</orientation>
<animation effect="fade" time="400">Visible</animation>
