How do you set your sabnzb+ to get folders, which xbmc can use?
most users have a folder structure like this:
tv shows
- lost
-- s01e01.avi
or
tv shows
- lost
-- s01
--- so1e01.avi
sabnzb+ doesn't overwrite the unpacked rar-files.
this results into fodlers like:
tv shows
- lost
- lost.1
- lost.2
my workaround is to use the automatic renaming.
now i have one root folder for every tvshow. and one extra folder for every single episode.
it works ... but it's kind of "ugly".
tv shows
- lost
-- s01e01
--- losts01e01.avi
-- s01e02
--- lost s01e02.avi
how do you setup your sabnzb+? or do you just use another way to unpack?
p.s.:
i've tried to post this in "offtopic" but i don't have the rights to post there ?!?
donabi Wrote:How do you set your sabnzb+ to get folders, which xbmc can use?
tv shows
- lost
-- s01e01.avi
or
tv shows
- lost
-- s01
--- so1e01.avi
tv shows
- lost
- lost.1
- lost.2
tv shows
- lost
-- s01e01
--- losts01e01.avi
-- s01e02
--- lost s01e02.avi
p.s.:
The best thing to do is have SAB extract\unpack the show to an "extracted" folder, which sickbeard monitors. It will then take care of the rest for you, as well as downloading future episodes of your favourite shows.
Have a read about it here
http://forum.xbmc.org/showthread.php?tid=63591
It will answer all your prayers and more!
nice.
have to look at it (and get it to work an my NAS
donabi Wrote:nice.
have to look at it (and get it to work an my NAS )
Sickbeard is an amazing piece of software. I highly recommend it.
Also, give Couch Potato a try. It has a firefox/chrome addon to automatically add movies to the queue from websites like the IMDB.
donabi Wrote:nice.
Ohhh, you've been missing out! SickBeard and CouchPotato rock my world (and get you extra brownie points with the WAF!)
Use SickBeard. Problem solved.
Anything else is just shooting yourself in the foot for no reason.
xecutionx Wrote:...give Couch Potato a try. It has a firefox/chrome addon to automatically add movies to the queue from websites like the IMDB.
What's the name of this Firefox add-on?
-Bob
TiGmsm Wrote:What's the name of this Firefox add-on?
-Bob
It's a UserScript, if you're on Chrome you can add this without installing an addon as it supports JavaScript addons standalone. For Firefox you'll need to install something along the lines of
Greasemonkey. You can then install the script from inside Couch Potato from what I remember.
There's alot of cool UserScripts out there so take a look around
http://userscripts.org
o.k.
sickbeard is quite perfect ... if you need your tvshows in english.
any other language isn't supported. or did i miss something?
donabi Wrote:o.k.
You could download your shows in german using RSS feeds and still let SB process them.
I use sickbeard but I still use sabnzbd for sorting my TV there is no problem with using any directory structure you like
I use
TV Show\Show Name\Season 1\Show.Name.S01E01.720p.ext
In sabnzbd for TV sorting I use the string below and "+Delete" for processing
%sn/Season %s/%s.n.S%0sE%0e.720p.%ext
without the 720p tag its
%sn/Season %s/%s.n.S%0sE%0e.%ext
which gives you
TV Show\Show Name\Season 1\Show.Name.S01E01.ext
You can also use
which just then unpacks to
Say if you wanted to run another renamer from a script in sabnzbd I've used this method to tag SD and HD differently I used the app below for this as its very simple but effective
http://tvrenamer.com/
Sickbeard gets its info from tvdb so its not only English thats supported if its on tvdb then you wont have a problem using it
I've tried both ways this weekend.
In the end, it doesn't work without the help of sickbeard.
It now does all the postprocessing (except unrar, which is done by sabnzbd+).
Here is my (german) guide:
http://www.xbmcnerds.com/index.php?page=...4#post5094
Now it is complete "Hands Free".
Thanks for all your tipps.
