Hi guys,
There are some movies that the xbmc didn't get the information.
How can I update for these the information manually?
Cheers
You can use the Web Interface Add-on XWMM - Web Media Manager
Just go in to Settings>Network>Services>Web Interface and change from Default to XWMM.
flaviosa Wrote:Hi guys,
Cheers
I think that pressing and holding the Menu button while you have a movie selected brings up the context menu. There should be a "Movie Information" selection within that list. Inside of "Movie Information" you can 'Refresh" the selection.
Real is correct. You can also change the behavior of what happens when you select a movie with the thumbnail. I have changed it from Play to Show Information. Go to Settings > Video > File Lists > Default slect action.
I view my movies in a wall to quickly see all that I have, then I select one thumbnails, press select and then I see movie info like plot, cast... You have the option to change the fanart, thumbnail AND Refresh the movie entry.
