Can someone point me to a how-to? The stickied page is thoroughly unhelpful. As far as I know, I'm running 10.1, and I want to run 10.5 to try out the Aeon 65 skin.
Um. 10.1 was just released. 10.5 doesn't exist.
Well, then what does it mean to "have the latest svn Build (nightly build) of XBMC 10.5 Dharma" mentioned on
this page?
And regardless, do you have any insight on updating live to non-release quality builds?
Use
Quote:sudo add-apt-repository ppa:team-xbmc/unstable && sudo apt-get update && sudo apt-get install xbmc -y
That will install the latest (unstable) svn of xbmc. Be warned it can cause issues.
cheers
Thanks! So I gather there are "nightly" builds which can be pretty unstable. Are there more stable builds besides the one released to the public?
Nope, if you really want the latest build you can get without compiling yourself, use the unstable ppa mentioned above. You can all ways revert to stable if you have issues. Dont forget to backup your ~/.xbmc/userdata dir just in case.
cheers
It means he's confusing people since 10.5 doesn't exist. Probably won't exist. And he needs to just say 'nightly builds'.
You can either add the svn ppa or download the .deb and install it.
darkscout Wrote:It means he's confusing people since 10.5 doesn't exist. Probably won't exist. And he needs to just say 'nightly builds'.
The svn ppa is not yet stable enough for that apparently, and the stickied thread is a bit of a clusterfuck. Hopefully once they've sorted it we should get a new thread.
