Full Version: Can someone supply a nightly build please?
The reason I ask is I don't want to post a skin problem I've encountered without first ruling out the possibility that the build I'm using (see below) isn't the cause.
This is the one I'm currently using to test out the new Video Library/Files feature -
watzen Wrote:here's a build. warning: backup library before running it. Just created it, so I haven't tried it myself.
http://www.megaupload.com/?d=FQ5PU0QB
I would have used Jezz's but it's been removed and the nightlies have stopped, so if someone could let me test out another recent build I can get to the bottom of the problem.
Many thanks,
Kev.
Here you go hitcher its 3 days old but the last one I built (no installer again) its the current git master which has the files in lib merged it
http://code.google.com/p/jezzxbmc/downlo...e=Xbmc.rar
Built on Mar 10 2011 (Git:d780887, compiler 1600)
Cheers Jezz, thankfully everything is working ok again so there must have been something amiss with that build because my panel view was spilling outside of the main control area.
