Full Version: [LIVE] epsxe
Does anyone out there have epsxe working for XBMC-Live? I can get it to load, but it shows up small in the upper left corner, and I can see XBMC underneath it. Whenever I try to configure video or sound, it kicks me back to XBMC. Same thing when I try to load an ISO.
I've tried configuring .epsxerc by hand, but that doesn't seem to work, or perhaps I'm not using the right arguments.
I would love to see a copy of .epsxerc from someone who has it working, even on full linux.
bump, anyone?
Look in this post, maybe it will direct you to have it working:
http://forum.xbmc.org/showpost.php?p=555...stcount=94
Ooo! Oooo!
Seriously uryu_ishida, please can you tel me how you got your EPSXE working.
I;ve been struggling with mine for aaages. What does your launcher config file look like?
Basically my problem is this... i set the launcher up with all recommeneded arguments... go to LAUNCHER in the add-ons part of XBMC...click the rom that i want to load, and the XBMC screen flickers once, XBMC goes small.... then just goes back to the ROMS list. Nothing appears to be running at all?
So how did you get your to actually RUN?
scalpel Wrote:Look in this post, maybe it will direct you to have it working:
Thanks, but it's not a problem with launcher, which launches the program just fine. It's a problem with epsxe and perhaps its configuration, as epsxe just quits whenever I try to open the video or audio configuration dialogs.
Would it be possible for you to send me your .epsxerc file? Thanks!
