Full Version: Can Not get 5.1
have a Zotac ZBOX HD-ID11-U Intel Atom D510 and I am feeding the tv with the HDMI output and from there I am feeding a Sony 5.1 receiver. (The Somy does not have HDMI inputs)
If I load the ZBox with XBMC 10.1 Windows version, I get sound on the tv and 5.1 pass through to the Sony.
If I load XBMC Linux on the ZBox, I get sound on the TV and it passes on to the Sony but not 5.1
I guess that it is the problem with my asound.conf file.
Can someone give me the right asound file format for this to work
My asound is as follows...............
pcm.!default {
type plug
slave {
pcm both
pcm.both {
type route
slave {
pcm multi
channels 4
ttable.0.0 1.0
ttable.1.1 1.0
ttable.0.2 1.0
ttable.1.3 1.0
pcm.multi {
type multi
slaves.a {
pcm tv
channels 2
slaves.b {
pcm receiver
channels 2
bindings.0.slave a
bindings.0.channel 0
bindings.1.slave a
bindings.1.channel 1
bindings.2.slave b
bindings.2.channel 0
bindings.3.slave b
bindings.3.channel 1
pcm.receiver {
type hw
card 0
device 0
channels 2
pcm.tv {
type hw
card 1
device 7
channels 2
aplay --list-devices
**** List of PLAYBACK Hardware Devices ****
card 0: Intel [HDA Intel], device 0: ALC888 Analog [ALC888 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: Intel [HDA Intel], device 1: ALC888 Digital [ALC888 Digital]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 0 [HDMI 0]
Subdevices: 1/1
aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
front:CARD=Intel,DEV=0
HDA Intel, ALC888 Analog
Front speakers
surround40:CARD=Intel,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Intel,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Intel,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Intel,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Intel,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Intel,DEV=0
HDA Intel, ALC888 Digital
IEC958 (S/PDIF) Digital Audio Output
hdmi:CARD=NVidia,DEV=0
HDA NVidia, HDMI 0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
HDA NVidia, HDMI 0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
HDA NVidia, HDMI 0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
HDMI Audio Output
root ~ #
My Audio in ZBMC
HDMI
5.1
Boost Check
AC3 Check
DTS Check
Custom
PCM.both
Custom
PCM.both
