2011-03-15, 17:48
Hello,
Fresh factory, update to 3.0.2, aTV Flash current. Broadcom (Crystal) and XBMC installed. Smart installer run.
In XBMC, the RSS feeds do not scroll. Weather updates the skin (temp shows, etc.) but selecting the weather menu item shows "internet connection required". Internet works fine, scrapers work fine, add-on install works, but RSS/Weather item do not.
22:21:04 T:52495360 M: 38277120 WARNING: FillBuffer: curl failed with code 28
22:21:04 T:52495360 M: 38277120 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
22:21:04 T:52495360 M: 38277120 DEBUG: FileCurl::Close(0xb03d5d70) http://feeds.feedburner.com/xbmc
22:21:04 T:52495360 M: 38277120 DEBUG: FileCurl::Open(0xb03d5d70) http://feeds.feedburner.com/xbmc
-bash-2.05b$ curl http://feeds.feedburner.com/xbmc - from cmd line returns all the data fine.
22:21:22 T:2684407808 M: 38346752 INFO: CheckIdle - Closing session to http://xoap.weather.com (easy=0xbdd2000, multi=0xc934910)
works fine on weather update. but when selecting the item, I don't see it try to grab the weather, just the fail message on the screen.
I have tried with and without ATVFlash (just general patchstick). I also found a thread that it was IPv6 related, so disabled IPv6 on the network as well as tried the settings in advancedsettings.xml with no luck. (My IPv6 connectivity if correct also.)
Any ideas?
Any ideas?
