Full Version: XBMC tvheadend access denied
First let me thank you all for all your efforts and time you have spent to create the best home theatre software available.
Before the last update on the 13/3/2011 xbmc was working fine with tvheadend, after updating to the new versions when I select LIVE TV there are no channels available and in the system>live tv>general>search for channels I get "No server support channel scanning".
While trying to fix the problem I had completely uninstalled both xbmc and tvheadend and did a clean install and the problem still exists.
Am I missing something?
Cheers,
subgr
I am using Ubuntu 10.04 32bit
Before update:
xbmc 2:10.0-pvr
hts-tvheadend
After update:
xbmc 2:11.0-pvr
tvheadend 2.12
tvheadend log:
Mar 15 23:49:41 htsp: Got connection from 127.0.0.1
Mar 15 23:49:41 htsp: 127.0.0.1: Welcomed client software: XBMC Media Center
Mar 15 23:49:41 htsp: 127.0.0.1 [ XBMC Media Center ]: Identified as user xbmc
Mar 15 23:49:43 htsp: 127.0.0.1 [ xbmc | XBMC Media Center ]: Disconnected
xbmc log:
23:49:41 T:3054233408 M:1241767936    INFO: Loading skin file: Startup.xml
23:49:41 T:2984356720 M:1241767936   DEBUG: PVR: Tvheadend HTSP Client - Creating PVR-Client AddOn
23:49:41 T:2984356720 M:1241767936   DEBUG: ADDON: Dll Initializing - Tvheadend HTSP Client
23:49:41 T:2984356720 M:1241767936   DEBUG: SECTION:LoadDLL(/usr/lib/xbmc/addons/pvr.hts/XBMC_Tvheadend.pvr)
23:49:41 T:2984356720 M:1241767936   DEBUG: Loading: /usr/lib/xbmc/addons/pvr.hts/XBMC_Tvheadend.pvr
23:49:41 T:3054233408 M:1241767936   DEBUG: Load Startup.xml: 8.31ms
23:49:41 T:3054233408 M:1241640960   DEBUG: Alloc resources: 8.74ms (8.72 ms skin load)
23:49:41 T:2984356720 M:1241640960   DEBUG: AddOnLog: xbmc.pvrclient/Tvheadend HTSP Client: Create - Creating Tvheadend PVR-Client
23:49:41 T:3054233408 M:1241640960    INFO: removing tempfiles
23:49:41 T:2984356720 M:1241640960   DEBUG: CAddonHelpers_Addon: AddOn Tvheadend HTSP Client request Setting host
23:49:41 T:3054233408 M:1241640960   DEBUG: ADDON: Starting service addons.
23:49:41 T:3054233408 M:1241640960  NOTICE: initialize done
23:49:41 T:3054233408 M:1241640960  NOTICE: Running the application...
23:49:41 T:3054233408 M:1241640960   DEBUG: ExecuteXBMCAction : Translating SetFocus(10)
23:49:41 T:3054233408 M:1241640960   DEBUG: ExecuteXBMCAction : To SetFocus(10)
23:49:41 T:3054233408 M:1241640960   DEBUG: Process - no profile autoexec.py (/home/xbmc/.xbmc/userdata/autoexec.py) found, skipping
23:49:41 T:3054233408 M:1241640960   DEBUG: NetworkMessage - Starting network services
23:49:41 T:3054233408 M:1241640960  NOTICE: Webserver: Starting...
23:49:41 T:3054233408 M:1241640960  NOTICE: WebServer: Started the webserver
23:49:41 T:2984356720 M:1241640960   DEBUG: CAddonHelpers_Addon: AddOn Tvheadend HTSP Client request Setting user
23:49:41 T:2984356720 M:1241640960   DEBUG: CAddonHelpers_Addon: AddOn Tvheadend HTSP Client request Setting pass
23:49:41 T:2984356720 M:1241640960   DEBUG: CAddonHelpers_Addon: AddOn Tvheadend HTSP Client request Setting htsp_port
23:49:41 T:2984356720 M:1241640960   DEBUG: CAddonHelpers_Addon: AddOn Tvheadend HTSP Client request Setting http_port
23:49:41 T:2984356720 M:1241640960   DEBUG: CAddonHelpers_Addon: AddOn Tvheadend HTSP Client request Setting skip_I_frame
23:49:41 T:2984356720 M:1241640960   DEBUG: CAddonHelpers_Addon: AddOn Tvheadend HTSP Client request Setting epg_offset_correction
23:49:41 T:2984356720 M:1241513984   DEBUG: AddOnLog: xbmc.pvrclient/Tvheadend HTSP Client: Connect - connecting to '127.0.0.1', port '9982'
23:49:41 T:2984356720 M:1241370624   DEBUG: AddOnLog: xbmc.pvrclient/Tvheadend HTSP Client: Connect - connected to server: [HTS Tvheadend], version: [2.12.99~git20110313.1aa214~odk1], proto: 5
23:49:41 T:2984356720 M:1241370624   ERROR: AddOnLog: xbmc.pvrclient/Tvheadend HTSP Client: ReadResult - access denied (1)
23:49:41 T:2984356720 M:1241370624   DEBUG: AddOnLog: xbmc.pvrclient/Tvheadend HTSP Client: ReadSuccess - failed to get reply from authentication with server
23:49:41 T:3025324912 M:1241370624   DEBUG: AddOnLog: xbmc.pvrclient/Tvheadend HTSP Client: HTSP Data Listener thread started (pid=3431, tid=3455)
23:49:41 T:3025324912 M:1241370624   DEBUG: AddOnLog: xbmc.pvrclient/Tvheadend HTSP Client: Action - Starting
after 2-3 hours of trying to understand why i dont see channels, i figured out that from now on you have to set the access configuration in the web tool:
check the tvheadend documentation:
http://www.lonelycoder.com/hts/tvheadend...index.html
scroll to :
4.1 Access configuration
Thank you a lot, that fixed the problem Smile
It took you 2-3 hours but 2-3 days for me Sad
Cheers
