2011-03-16, 10:03
The problem I am having is not limited to XBMC it also happens when i play files in VLC. I am receiving random horizontal lines on the screen when playing back video. These lines are not constant but appear during only certain scenes. The original resolution is below 1080, more around 720 (it is only in the top half of the screen in which this occurs). So I am wondering if this is just the gfx card or some other piece of hardware.
Setup:
Intel Core 2 Duo 3.16
4 gb of DDR2
GT 240 1024mb of DDR3 (with the latest drivers)
1 TB baracuda drive
Stats when playing at 1920x1080 resolution:
Memory at a steady 19%
either CPU never goes about 21%
XBMC version 10.1
monitor running at 60hz
open GL 3.3.0
Test I have done:
I have tried two different monitors to see if the refresh rate could have something to do with it.
I am about to try my HD 5750 to see if its really the gfx card. I have enabled Vsync it has not helped. Additionally, I tried to take screenshots but was unsuccessful to actually capture the lines
I am running ubuntu 10.10 could this be a problem?
*Edit: Just tested out the HD 5750...which worked flawlessly at 90hz. Is the gtx 240 a faulty card? I bought this after seeing what people had said about it, ie: "It would play 1080 flawlessly" 'tis not the case
Setup:
4 gb of DDR2
1 TB baracuda drive
XBMC version 10.1
open GL 3.3.0
Test I have done:
