2011-03-16, 12:55
I have XBMC Live installed in my living room controlling it with a MCE remote. It is a bit annoying to have additional remotes for only turning on/off an LG TV (one press), and on/off + volume on passthrough on my NAD T743 Receiver.
I would like to use XBMC to control the TV and the receiver, I have search a bit in this forum, and also found a wiki, saying that this is possible, if I have the correct hardware, supported by LIRC.
It seems like the remote I already have, has some emitter/tramsmitter funktion, this is the one:
http://cgi.ebay.com/OEM-HP-MCE-KIT-REMOT...3166wt_905
There are two jacks on the back of the box, and it had one IR-LED in the box.
I would like to know If I could use this for my purpose, or do I need to get some additional hardware.
The XBMC box is a Zitac IONITX board, which doesnt have Serial, so if the hardware I have cannot work, I probadly need to find some USB Transmitter that works, any suggestions is very welcome.
Sincerely
Sincerely
