Full Version: Irregular Characters - Naming
I'm having trouble getting XMBC to scrape the following show: Haré+Guu. I double-checked http://thetvdb.com/ to make sure I had the name exactly right and the episodes right for the right season. My file name format is "Haré+Guu - S01E02 - Siesta Guu Guu". This is the same format that I use for all of the other shows I have. All I can think of is that the "é" character might be throwing it off? Maybe the +?
Just wondering if there were some known character issues that cause scraping problems. I couldn't find anything searching around.
Any help would be appreciated<3:confused2:
just took a quick look at it and the only thing that I see would be to add the deluxe or final prefix but seeing as they both have the same show id I am not sure if it would be of benifit or not. another thing you could try is using the tvrename program.
http://www.tvrename.com/
Use an nfo file.
