2011-03-19, 15:34
I upgraded XBMC recently and can't seem to find the "Allow to control XBMC via HTTP" option anymore? I would like to be able to control XBMC using Android XBMC remote like I did before.
Kuasii Wrote:I'm using gentoo as well and have the same problem. What was your fix?
htpc ~ # equery uses xbmc
[ Searching for packages matching xbmc... ]
[ Colour Code : set unset ]
[ Legend : Left column (U) - USE flags from make.conf ]
[ : Right column (I) - USE flags packages was installed with ]
[ Found these USE variables for media-tv/xbmc-9999 ]
U I
+ + alsa : Adds support for media-libs/alsa-lib (Advanced Linux Sound Architecture)
- - altivec : Adds support for optimizations for G4 and G5/ppc970 processors
- - avahi : Add avahi/Zeroconf support
- - bluray : Enable playback of Blu-ray filesystems
+ + css : Enables reading of encrypted DVDs
- - debug : Enable extra debug codepaths, like asserts and extra output. If you want to get meaningful backtraces see http://www.gentoo.org/proj/en/qa/backtraces.xml
- - joystick : Add support for joysticks in all packages
- - midi : Support MIDI files
- - profile : Adds support for software performance analysis (will likely vary from ebuild to ebuild)
- - pulseaudio : Adds support for PulseAudio sound server
- - rtmp : Enable Real Time Messaging Protocol using librtmp
+ + sse : fast floating point optimization for PentiumIII+ class chips
+ + sse2 : faster floating point optimization for SSE2 capable chips
+ + udev : Enable sys-fs/udev integration (device discovery, power and storage device support, etc)
- - vaapi : Enables VAAPI (Video Acceleration API) for hardware decoding
+ + vdpau : enable support for Video Decode and Presentation API for Unix
- - webserver : Enable internal webserver
- + xrandr : Support X randr extension
