jacaru Wrote:My bad, I was not creating an UDF filesystem within the ISO.
ISO is stuttering the same for me as the VIDEO_TS.
I will try to create a small DVD to copy it locally to ATV2. I will try also a nightly for OSX to compare.
I tried the last osx nightly of May1st and dvd playfine.
About the small dvd copied locally to ATV2, it shows the same issue. So we can forget about network&protocol issues.
jd2157 Wrote:Agreed, good error report and that the mkv is encoded /w mpeg2 but looks like the WMV is encoded with VC-1. Either way there's no hardware acceleration for either so neither's going to look too good on the atv2.
Is that correct? I would easily understand that if the CPU was at 100% (or nearly) as it would be the software doing the decoding, but the CPU is not reaching nearly that high. The same MKV file will also play fine with no stuttering or buffering issues if I revert from the nightly to the version available from the main repository (10.0-7). I upgraded to the nightly in hopes of the WMV issue improving.
OCJon76 Wrote:Is that correct? I would easily understand that if the CPU was at 100% (or nearly) as it would be the software doing the decoding, but the CPU is not reaching nearly that high. The same MKV file will also play fine with no stuttering or buffering issues if I revert from the nightly to the version available from the main repository (10.0-7). I upgraded to the nightly in hopes of the WMV issue improving.
It's correct that there's no hardware acceleration for any codec other than h264/x264 on the atv2. So for any HD content that will likely cause choppy playback... far as I know.
Interesting that the MKV files was ok on other versions of XBMC. Mustn't have been a very high res or bitrate... I confess I didn't check them in the mediainfo output.
I am experiencing a problem with playback of .mp4 files. Very choppy, fps down to 10-12
Not sure if mp4 files are hardware accelerated so maybe its due to that, but hears the report…
Platform: ATV2
iOS version: 4.1.1
XBMC Build: XBMC PRE-11.0 Git: 20110430-f5e63e6 (Compiled: May 2 2011)
Installed with dpkg -i latest_atv2.deb
XBMC log:
http://pastebin.com/7NYicd3r
Media Info:
http://pastie.org/pastes/1876223
(Happy to upload media sample if required and if you could advise what software available (osx))
Playback fine on Platform: Mac OS X (10.7.0 i386). Built on Apr 18 2011 (Git:20110418-6281a05)
Kind regards,
FT
fattoony Wrote:I am experiencing a problem with playback of .mp4 files. Very choppy, fps down to 10-12
Platform: ATV2
iOS version: 4.1.1
XBMC log: http://pastebin.com/7NYicd3r
Media Info: http://pastie.org/pastes/1876223
Kind regards,
FT
I might be wrong, but could line 170 have anything to do with it?
Quote:22:56:19 T:159367168 M:124203008 DEBUG: FactoryCodec - Video: vtb - Opening
22:56:19 T:159367168 M:124203008 DEBUG: FactoryCodec - Video: vtb - Failed
22:56:19 T:159367168 M:124203008 DEBUG: FactoryCodec - Video: - Opening
Does vtb fail mean VideoToolBox ?
Platform: ATV2
iOS version: 4.3
Apple TV version: 4.2.1
XBMC Build: 2 May
I am also seeing choppy playback with MKV (720p / h264), was fine with 17 April build.
Keith - thanks for the NIGHTLY BUILD as it was able to get all the ADDONs running again. At least all that would work, without crashing XBMC
Can I make a request?
Can you attach the code for Slingbox aka Slingplayer for XBMC into your NIGHTLY BUILD?
The following thread discusses SLINGBOX on the XBMC platform.
http://forum.xbmc.org/showthread.php?tid=82597
I will test this out, as I have access to my remote SLINGBOX and I can handle the simple installation of a DEB file.
Platform: ATV2
iOS version: 4.3
XBMC Build: 7 May
I would like to get my atv2 xbmc on the same shared mysql database as my other xbmc clients. Right now the atv2 box has to have its own database as it is a newer database version that is incompatible with the production release of 10.1 that is running on my windows and openelec instances. Any idea of when the atv2/ios line and the other lines will be on the same database version again?
thx
claypigeon Wrote:I would like to get my atv2 xbmc on the same shared mysql database as my other xbmc clients. Right now the atv2 box has to have its own database as it is a newer database version that is incompatible with the production release of 10.1 that is running on my windows and openelec instances. Any idea of when the atv2/ios line and the other lines will be on the same database version again?
thx
Not for a while, but you can run nightlies in osx/lin/win builds until then:
http://mirrors.xbmc.org/nightlies/
But you have an obligation to report issues.
That's really whats stopping official builds is the database mismatch. We probably won't rev officially until everything else uses the same db.
ktjensen Wrote:Keith - thanks for the NIGHTLY BUILD as it was able to get all the ADDONs running again. At least all that would work, without crashing XBMC
Platform: ATV2
iOS version: 4.3
XBMC Build: 7 May
Interesting! I will definitely look into making you a one-off build sometime, I don't think I can get to it this weekend, but I'll try. Get me on IRC or PM me offline or something if I forget.
Mr Zippy Wrote:Platform: ATV2
iOS version: 4.3
XBMC Build: 2 May
pastebin a log with debugging enabled, also try the newer build.
Cranial is right, but that mediainfo does look AVC so unsure why it failed.
You can use:
http://www.xs4all.nl/~loekjehe/Split&Concat/
for a 'gui' to split, but the lazy way I usually do it is:
split -b 100m (filename)
and then use another terminal window to verify its onto the 2nd file and just ctrl-c it, and then test the first 100mb file. If the problem is there, I send that.
You could also do 50mb if it happens immediately.
If you could install the new build and test that first that'd be great too!
Hi Keith,
Tested on May 7th (Git:20110507-4b18017) same problem as before.
Included some new logs and a 50MB sample.
Should also point out that the mp4’s that I am having trouble with are downloaded from bbc-iplayer via “get iplayer automator”.
Don’t have any other .mp4 from a different source to test. But I’m pretty sure that they played ok before I started running the nightly.
Platform: ATV2
iOS version: 4.1.1
XBMC Build: May 7 (Git:20110507-4b18017)
XBMC log:
http://pastebin.com/sBhK97DF
Media Info:
http://pastie.org/pastes/1878906
Media sample:
http://dl.dropbox.com/u/3955256/Doctor%2...ot.nfo.mp4
Kind regards,
FT
Keith,
Your last build, how do I figure out the last commit included in that build?
I'm running Git:20110508-1d0c2f3 and there appears to be a bug where LCD Video Calibration is not being saved.
I think it might be related to this commit:
[osx] Workaround to fix fullscreen switching in multi monitor setup. but I can't be sure.
*Edit* Just reverted to your May 07 build Keith and I can confirm this bug was introduced since then.
Cranial Wrote:Keith,
I think it might be related to this commit: [osx] Workaround to fix fullscreen switching in multi monitor setup. but I can't be sure.
if you change
#if defined __APPLE__
to
#if defined(__APPLE__) && !defined(__arm__)
in xbmc/guilib/GraphicContext.cpp ( line 310 ) does that fix the issue ?
