HI, I reinstalled windows to a ssd, in the process i changed system to achi mode i do see all the drives from the new install, but did have to change ownership to main user mode, I installed xbmc and i added all the folders, XBMC does scan the folders but picks up nothing
if i go into each seperate folder and pick out items individually and ask for movie/tv show info, it will scrape the info in,,, not really a process i want to do for a database of 850 movies and 20 or so tv shows,,,,
I am thinking there is something not set right to make it scrape info to rebuild the database.
If you provide your log file (%APPDATA%\XBMC\xbmc.log), you may have better luck receiving help as this will help us determine the problem.
here it is, i had to do copy & paste, don't know if/how to do attachments, i did some erasing to make it fit, mostly stuff about screens
:34:55 T:3316 M:3082457088 NOTICE: -----------------------------------------------------------------------
10:34:55 T:3316 M:3082444800 NOTICE: Starting XBMC, Platform: Windows 7, 64-bit (WoW) build 7600. Built on Mar 8 2011 (Git:e9e9099, compiler 1500)
10:34:55 T:3316 M:3082444800 NOTICE: AMD Athlon II X3 445 Processor
10:34:55 T:3316 M:3082440704 NOTICE: Desktop Resolution: 1680x1050 32Bit at 60Hz
10:34:55 T:3316 M:3082436608 NOTICE: Running with restricted rights
10:34:55 T:3316 M:3082436608 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
10:34:55 T:3316 M:3082436608 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
10:34:55 T:3316 M:3082436608 NOTICE: special://masterprofile/ is mapped to: C:\Users\Monkey\AppData\Roaming\XBMC\userdata
10:34:55 T:3316 M:3082436608 NOTICE: special://home/ is mapped to: C:\Users\Monkey\AppData\Roaming\XBMC
10:34:55 T:3316 M:3082436608 NOTICE: special://temp/ is mapped to: C:\Users\Monkey\AppData\Roaming\XBMC\cache
10:34:55 T:3316 M:3082436608 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
10:34:55 T:3316 M:3082436608 NOTICE: Log File is located: C:\Users\Monkey\AppData\Roaming\XBMC\xbmc.log
10:34:55 T:3316 M:3082436608 NOTICE: -----------------------------------------------------------------------
10:34:55 T:3316 M:3082416128 NOTICE: Setup SDL
10:34:55 T:3316 M:3081580544 NOTICE: Found screen: Generic PnP Monitor on NVIDIA GeForce GTX 460, adapter 0.
10:34:55 T:3316 M:3081576448 NOTICE: Found screen: Generic PnP Monitor on NVIDIA GeForce GTX 460, adapter 1.
10:34:55 T:3316 M:3081564160 NOTICE: Primary mode: 1680x1050 @ 60.00 - Full Screen
10:34:55 T:3316 M:3081564160 NOTICE: Secondary mode: 1360x768 @ 60.00 - Full Screen #2
10:34:55 T:3316 M:3081420800 NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
10:34:55 T:3316 M:3081457664 NOTICE: Previous line repeats 2 times.
59.94 - Full Screen #2
10:34:55 T:3316 M:3079712768 NOTICE: Additional mode: 1440x900 @ 60.00 - Full Screen #2
10:34:55 T:3316 M:3079294976 NOTICE: Previous line repeats 2 times.
10:34:55 T:3316 M:3079294976 NOTICE: Additional mode: 1440x900 @ 24.00 - Full Screen #2
10:34:55 T:3316 M:3079294976 NOTICE: Additional mode: 1440x900 @ 23.98 - Full Screen #2
10:34:55 T:3316 M:3079294976 NOTICE: Additional mode: 1440x900 @ 30.00 - Full Screen #2
10:34:55 T:3316 M:3079294976 NOTICE: Additional mode: 1440x900 @ 29.97 - Full Screen #2
10:34:55 T:3316 M:3080253440 NOTICE: Previous line repeats 2 times.
10:34:55 T:3316 M:3080253440 NOTICE: load settings...
10:34:55 T:3316 M:3080179712 NOTICE: special://profile/ is mapped to: special://masterprofile/
10:34:55 T:3316 M:3080179712 NOTICE: loading special://masterprofile/guisettings.xml
10:34:55 T:3316 M:3080151040 NOTICE: Getting hardware information now...
10:34:55 T:3316 M:3080151040 NOTICE: Checking resolution 11
10:34:55 T:3316 M:3080142848 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
10:34:55 T:3316 M:3080130560 NOTICE: Loaded playercorefactory configuration
10:34:55 T:3316 M:3080130560 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
10:34:55 T:3316 M:3080130560 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
10:34:55 T:3316 M:3080130560 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
10:34:55 T:3316 M:3080130560 NOTICE: Default DVD Player: dvdplayer
10:34:55 T:3316 M:3080130560 NOTICE: Default Video Player: dvdplayer
10:34:55 T:3316 M:3080130560 NOTICE: Default Audio Player: paplayer
10:34:55 T:3316 M:3080114176 NOTICE: Loading media sources from special://masterprofile/sources.xml
10:34:56 T:3316 M:3062001664 NOTICE: initializing playlistplayer
10:34:56 T:3316 M:3062001664 NOTICE: DONE initializing playlistplayer
10:34:56 T:3316 M:3053006848 NOTICE: CApplication::UpdateLibraries - Starting video library startup scan
10:34:56 T:3316 M:3052945408 NOTICE: CApplication::UpdateLibraries - Starting music library startup scan
10:34:56 T:1964 M:3052732416 NOTICE: VideoInfoScanner: Starting scan ..
10:34:56 T:3316 M:3052302336 NOTICE: initialize done
10:34:56 T:3316 M:3052302336 NOTICE: Running the application...
10:34:56 T:3316 M:3052281856 NOTICE: Webserver: Starting...
10:34:56 T:3160 M:3050422272 NOTICE: My Music: Scanning for music info using worker thread, operation took 00:00
10:34:56 T:3316 M:3050422272 NOTICE: WebServer: Started the webserver
10:34:56 T:3316 M:3050422272 NOTICE: starting upnp server
10:34:56 T:3316 M:3049689088 NOTICE: starting upnp renderer
10:34:56 T:3316 M:3049697280 NOTICE: ES: Starting event server
10:34:56 T:2848 M:3049689088 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
10:34:56 T:2848 M:3049668608 NOTICE: UDP: Listening on port 9777
10:35:04 T:1964 M:3032084480 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:07
10:35:06 T:3316 M:3030523904 NOTICE: Storing total System Uptime
10:35:06 T:3316 M:3030781952 NOTICE: Saving settings
10:35:06 T:3316 M:3030626304 NOTICE: stop all
10:35:06 T:3316 M:3030626304 NOTICE: ES: Stopping event server
10:35:06 T:3316 M:3030642688 NOTICE: stopping upnp
10:35:06 T:2848 M:3031080960 NOTICE: ES: UDP Event server stopped
10:35:07 T:3316 M:3031134208 NOTICE: Webserver: Stopping...
10:35:07 T:3316 M:3031146496 NOTICE: WebServer: Stopped the webserver
10:35:07 T:3316 M:3031171072 NOTICE: Webserver: Stopped...
10:35:07 T:3316 M:3031171072 NOTICE: stop sap announcement listener
10:35:07 T:3316 M:3031171072 NOTICE: clean cached files!
10:35:07 T:3316 M:3031191552 NOTICE: unload skin
10:35:07 T:3316 M:3033808896 NOTICE: stop python
10:35:07 T:3316 M:3049316352 NOTICE: stopped
10:35:07 T:3316 M:3049320448 NOTICE: destroy
10:35:07 T:3316 M:3049566208 NOTICE: unload sections
i self solved this one, I had changed ownership of drives in between when xbmc was open,, i erased video sources and re added, all good now it seems
