As of version 0.9 PVR support was added to reFocus. Because XBMC's official releases do not contain the PVR support yet I will have to do development and testing on two XBMC versions at least for a while.
In order to keep bug reports for both XBMC flavors separate, please post PVR related bugs in this thread.
Non-PVR related bugs can keep on being reported in the
reFocus release thread as usual.
Thanks,
Jeroen
when you click info on a channel and it brings up the option to "switch, record or ok", if the epg information is long the last line is behind those buttons and so doesnt look nice.
When you click on a channel and it appears in the small window, if the epg is long it scrolls up from the bottom of the screen and again doesnt look nice.
On Dushmaniac's pvr build you have to rename MyTV to MyPVR like described in the other thread, also a question mark icon appears over all tv channel icons.
Also in the recordings view, not a bug, but is it possible to have any different views yet with the pvr version? Would be nice in slide view with thumbnails of the recordings. Also in recordings view, it doesnt list the channel the program was recorded on. Would be useful for people who dont have channel logos.
Hey ....
The Download link on GoogleCode seems to be broken ...
Quote:404. That’s an error.
The requested URL /p/xbmc-focus/downloads/detail?name=reFocus.PR2-0.9.zip was not found on this server. That’s all we know.
Thanks for this great skin.
1. No channel info comes when channel switch.
2. Channel logos can't change
nasuh Wrote:1. No channel info comes when channel switch.
Make sure "show channel information when switching channels" is enabled in tv settings->menu/osd.
I can't check it right now as my PVR install only lists channels, playback won't work
Quote:2. Channel logos can't change
Yes, that's a work in progress at the moment.
"show channel information when switching channels" is enabled and works with confluence.
Any change for fetch logos with like "$INFO[channel.name].png" string editing xml files etc?
Cant get any of my channel icons to show, is this not supported or can i fix it somehow?
nasuh Wrote:Any change for fetch logos with like "$INFO[channel.name].png" string editing xml files etc?
jolid Wrote:Cant get any of my channel icons to show, is this not supported or can i fix it somehow?
It's not supported at the moment. There were some issues with this and other PVR related things and eventually I chose to not let it delay the release of 0.9.1 further.
So, the PVR will be getting more attention in the next release.
i could solve channel logo by editing IncludesFlags.xml. One thing i want to change info panel when channel switch which xml files control this (channel info when switch) please help?
Channel info only shows in confluence when channel switching. All the other skins not shows this info. I think latest xbmc build some controls changed. Because one thing i need is infos when channel switch please solve this issue or show the way how or advice.
nasuh Wrote:Channel info only shows in confluence when channel switching. All the other skins not shows this info. I think latest xbmc build some controls changed. Because one thing i need is infos when channel switch please solve this issue or show the way how or advice.
I thought there is an option in settings to show channel info on switching. Am i wrong?
you right. Settings->LiveTV->Menu/OSD -- "Show channel info when switching channels" enabled. And works in confluence but in all other skins (also cirrus) not work.
Same problem here.
Channel info shows fine in confluence when switching, but with all other skins i only get the progress bar / playback status shown, no channel info.
Using Opdenkamps PPA built on ubuntu.
