Full Version: XBMC crahses
Hi!
I have tried to look for this problem but not found anything useful yet.
The problem is that XBMC just shutsdown when I try to open a movie/tv show.
I here the sound for about a sec then it's away and I return to my desktop.
It worked a couple of days ago, and I have tried to reinstall with Ubuntu Installation Manager. Any ideas of the cause?
I attach the XBMC crashlog here.
The file was to big so I erased the Stack data.
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: sön 20 mar 2011 21.19.34 CET
XBMC Options:
Arch: i686
Kernel: Linux 2.6.32-30-generic #59-Ubuntu SMP Tue Mar 1 21:30:21 UTC 2011
Release:
    Distributor ID:    Ubuntu
    Description:    Ubuntu 10.04.2 LTS
    Release:    10.04
    Codename:    lucid
############## END SYSTEM INFO ##############
################# LOG FILE ##################
21:19:17 T:3078416240 M:3093897216  NOTICE: -----------------------------------------------------------------------
21:19:17 T:3078416240 M:3093516288  NOTICE: Starting XBMC, Platform: Linux (Ubuntu 10.04.2 LTS, 2.6.32-30-generic i686). Built on Mar  9 2011 (Git:Unknown)
21:19:17 T:3078416240 M:3093516288  NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
21:19:17 T:3078416240 M:3093516288  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
21:19:17 T:3078416240 M:3093516288  NOTICE: special://masterprofile/ is mapped to: /home/markus/.xbmc/userdata
21:19:17 T:3078416240 M:3093516288  NOTICE: special://home/ is mapped to: /home/markus/.xbmc
21:19:17 T:3078416240 M:3093516288  NOTICE: special://temp/ is mapped to: /home/markus/.xbmc/temp
21:19:17 T:3078416240 M:3093516288  NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
21:19:17 T:3078416240 M:3093516288  NOTICE: Log File is located: /home/markus/.xbmc/temp/xbmc.log
21:19:17 T:3078416240 M:3093516288  NOTICE: -----------------------------------------------------------------------
21:19:18 T:3078416240 M:3093569536  NOTICE: Setup SDL
21:19:18 T:3078416240 M:3093598208  NOTICE: load settings...
21:19:18 T:3078416240 M:3093622784  NOTICE: special://profile/ is mapped to: special://masterprofile/
21:19:18 T:3078416240 M:3093622784  NOTICE: loading special://masterprofile/guisettings.xml
21:19:18 T:3078416240 M:3093241856  NOTICE: Getting hardware information now...
21:19:18 T:3078416240 M:3093241856  NOTICE: Checking resolution 12
21:19:18 T:3078416240 M:3093241856  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
21:19:18 T:3078416240 M:3093323776  NOTICE: Loaded playercorefactory configuration
21:19:18 T:3078416240 M:3093323776  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
21:19:18 T:3078416240 M:3093323776  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
21:19:18 T:3078416240 M:3093323776  NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
21:19:18 T:3078416240 M:3093323776  NOTICE: Default DVD Player: dvdplayer
21:19:18 T:3078416240 M:3093323776  NOTICE: Default Video Player: dvdplayer
21:19:18 T:3078416240 M:3093323776  NOTICE: Default Audio Player: paplayer
21:19:18 T:3078416240 M:3093323776  NOTICE: Loading media sources from special://masterprofile/sources.xml
21:19:19 T:3078416240 M:3068588032  NOTICE: Using visual 0x51
21:19:19 T:3078416240 M:3066724352  NOTICE: GL_VENDOR = ATI Technologies Inc.
21:19:19 T:3078416240 M:3066724352  NOTICE: GL_RENDERER = ATI Radeon HD 5400 Series
21:19:19 T:3078416240 M:3066724352  NOTICE: GL_VERSION = 3.2.9756 Compatibility Profile Context
21:19:19 T:3078416240 M:3066724352  NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.50
21:19:19 T:3078416240 M:3066597376   ERROR: GLX: Same window as before, refreshing context
21:19:20 T:3078416240 M:3066802176  NOTICE: UDisks: Added /media/46A81F42A81F2FC3
21:19:20 T:3078416240 M:3066802176  NOTICE: UDisks: Added /media/D2FCE51BFCE4FB1D
21:19:20 T:3078416240 M:3066802176  NOTICE: UDisks: Added /media/EEA8981FA897E3FD
21:19:20 T:3078416240 M:3066802176  NOTICE: start dvd mediatype detection
21:19:20 T:3078416240 M:3066802176  NOTICE: initializing playlistplayer
21:19:20 T:3078416240 M:3066802176  NOTICE: DONE initializing playlistplayer
21:19:20 T:3078416240 M:3062620160  NOTICE: initialize done
21:19:20 T:3078416240 M:3062620160  NOTICE: Running the application...
21:19:20 T:3078416240 M:3062620160  NOTICE: ES: Starting event server
21:19:20 T:3078416240 M:3062493184  NOTICE: DS: Starting dbus server
21:19:20 T:3024354160 M:3062493184  NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
21:19:20 T:3024354160 M:3062493184  NOTICE: UDP: Listening on port 9777
21:19:20 T:2932902768 M:3062493184  NOTICE: DS: Starting DBUS server in Run Application aka thread
21:19:20 T:3078416240 M:3062493184  NOTICE: starting zeroconf publishing
21:19:29 T:3078416240 M:3059388416  NOTICE: DVDPlayer: Opening: rar://%2fmedia%2f46A81F42A81F2FC3%2fScene%2fMovies%2f1%2d9%2f2%2e22%2e2008%2eFESTiVAL%2eNORDiC%2ePAL%2eDVDR%2dTV2LAX9%2ftv2lax9%2d222%2erar/tv2lax9-222.img
21:19:29 T:3078416240 M:3059388416 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
21:19:29 T:2869943152 M:3059388416  NOTICE: Creating InputStream
21:19:29 T:2869943152 M:3059564544 WARNING: dll_ioctl - 21392 request failed with error [2] Filen eller katalogen finns inte
21:19:30 T:2869943152 M:3059777536  NOTICE: DVDPlayer: playing a dvd with menu's
21:19:30 T:2869943152 M:3059777536  NOTICE: Creating Demuxer
21:19:30 T:2869943152 M:3055210496 WARNING: could not find codec parameters for rar://%2fmedia%2f46A81F42A81F2FC3%2fScene%2fMovies%2f1%2d9%2f2%2e22%2e2008%2eFESTiVAL%2eNORDiC%2ePAL%2eDVDR%2dTV2LAX9%2ftv2lax9%2d222%2erar/tv2lax9-222.img
21:19:30 T:2869943152 M:3055210496  NOTICE: Opening Subtitle stream: 0 source: 512
21:19:30 T:2869943152 M:3055210496 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
21:19:30 T:2869943152 M:3055210496 WARNING: CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED
21:19:30 T:2869943152 M:3055083520  NOTICE: Opening video stream: 0 source: 256
21:19:30 T:2869943152 M:3055083520  NOTICE: Creating video codec with codec id: 2
21:19:30 T:2869943152 M:3055083520  NOTICE: Creating video thread
21:19:30 T:2853157744 M:3054514176  NOTICE: running thread: video_thread
21:19:30 T:2853157744 M:3052843008  NOTICE:  fps: 25.000000, pwidth: 720, pheight: 576, dwidth: 1024, dheight: 576
21:19:30 T:2853157744 M:3052843008  NOTICE: Display resolution DESKTOP : 1360x768 @ 60.02 - Full Screen (12)
21:19:30 T:2869943152 M:3050811392  NOTICE: Opening video stream: 0 source: 256
21:19:30 T:2869943152 M:3050811392  NOTICE: Closing video stream
21:19:30 T:2869943152 M:3050811392  NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
21:19:30 T:2869943152 M:3050811392  NOTICE: waiting for video thread to exit
21:19:30 T:2853157744 M:3050811392   ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
21:19:30 T:2853157744 M:3050811392  NOTICE: thread end: video_thread
21:19:30 T:2869943152 M:3050811392  NOTICE: deleting video codec
21:19:30 T:2869943152 M:3052589056  NOTICE: Creating video codec with codec id: 2
21:19:30 T:2869943152 M:3052589056  NOTICE: Creating video thread
21:19:30 T:2853157744 M:3052589056  NOTICE: running thread: video_thread
21:19:30 T:2869943152 M:3052589056  NOTICE: Opening audio stream: 1 source: 256
21:19:30 T:2869943152 M:3052462080  NOTICE: Finding audio codec for: 86020
21:19:30 T:2869943152 M:3050938368  NOTICE: Creating audio thread
21:19:30 T:2842688368 M:3050938368  NOTICE: running thread: CDVDPlayerAudio::Process()
21:19:30 T:2842688368 M:3050938368  NOTICE: Creating audio device with codec id: 86020, channels: 2, sample rate: 48000, no pass-through
21:19:32 T:3078416240 M:3046649856  NOTICE: Using GL_TEXTURE_2D
21:19:32 T:3078416240 M:3046060032  NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
21:19:33 T:3078416240 M:3041787904   ERROR: (pthread_mutex_destroy(&m_mutex)): [XCriticalSection.cpp:84] 16
21:19:33 T:2853157744 M:3041787904  NOTICE:  fps: 25.000000, pwidth: 720, pheight: 576, dwidth: 1024, dheight: 576
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
Turn debug logging on and try again. (Settings->System->Debugging).
Here is a debug log, it was to big to insert in the code so please find it at http://pastebin.com/SNesBW56
At a guess, there's a graphics driver issue, in that it's calling some sort of forced exit after compiling the shaders.
Set it to use ARB shaders rather than GLSL, rejoice that it works, then curse ATI for their broken drivers.
(Mayaswell be optimistic, right?)
Cheers,
Jonathan
Works perfect with the ARB setting. Thanks for helping out Smile
Great Smile
jmarshall Wrote:At a guess, there's a graphics driver issue, in that it's calling some sort of forced exit after compiling the shaders.
Cheers,
Jonathan
Exactly the same debug output here too. Grrr... happened after the apt-get update followed by apt-get install xbmc to get the 10.1.
JM, please - how/where do I change the shaders to ARB ...?
Don't worry, found it - daft me... never even bothered to look into the Renderer options; always had it on Auto...
Darn ATi ... when it works, it's a pure pleasure, but boy... don't UPDATE once you get it working...
Had excatly the same issue with XBMC Live and AMD HD 5450 graphics card. The change above also fixed my no video followed by crash issue.
Now I have video, but have to work out why there is no sound over the 5450 HDMI...
Cheers!
EDIT: Found solution here http://forum.xbmc.org/showthread.php?tid=88194
