2012-06-19, 14:52
2012-07-29, 15:39
Version 3.0.4 is in the repo.
Changelog:
3.0.4
Fixed: "The Big Picture"-scraper
Fixed: "Wallstreet Jouarnal"-scraper
Changelog:
3.0.4
2012-11-16, 04:32
Is anyone else having problems with the time.com photos ?
The main "Index" photos show up, but when I try to enter that series of photos, the loading indicator just spins and spins and spins.
Is it just my problem or does anyone else experiencing the same issue ? Are the photos region restricted ?
2012-11-16, 09:04
Correct, Time.com Photos are broken - I already fixed it but didn't requested a Pull to the Repo.
2012-11-16, 18:26
(2012-11-16, 09:04)sphere Wrote: [ -> ]Correct, Time.com Photos are broken - I already fixed it but didn't requested a Pull to the Repo.
I manually made the changes to the python script and it works fine.
Thanks for your help and your great plugins.. Especially the "Big Picture". We usually use it daily.
Once I get my hardware all working correctly. My next step is to read up on plugin development so that I can create some plugins and help with bug in others.
Cheers !
2012-11-19, 10:23
The Update is now in the Repo.
Changelog:
Changelog:
Fixed: Time.com Lightbox photosets
Updated Translations
2013-01-31, 22:05
sphere - is there anyway to set this up to run as the screensaver with the context of the photos?
2013-01-31, 22:06
I will release a screensaver version of this Add-on in a few days
2013-01-31, 22:07
(2013-01-31, 22:06)sphere Wrote: [ -> ]I will release a screensaver version of this Add-on in a few days
Sweet
2013-02-07, 01:06
Anxiously awaiting this. Thanks for your time and effort
2013-02-25, 21:54
Sphere - do you have any update on the screen saver version?
2013-02-26, 12:07
Unfortunately not
I will announce here when a test version is available
2013-02-26, 13:44
Np. Thank you
2013-03-05, 00:09
Version 4.0.0 is ready to be tested!
I needed to split up the scraper part from the GUI part so you need to install two modules!
(Later when the Add-on is available in the official xbmc.org add-on repository this will be solved (and updated) automatically)
You can download it here:
Scraper Module Version 1.0.0
The Big Pictures Script Version 4.0.0
It is (again) a nearly complete rewrite, it should be faster and more robust. There is also new Scraper included:
NewYorkTimes.com - Lens Blog
It has also a slightly different look (thx to Jugger) and you need to tell me if you like it or not! Much users told me that they got confused by the album- and photo-views, this should be fixed now. The pictures will be shown at 70% size when you are in albums mode.
Please give me some feedback, even if it's just "it works, I like".
regards,
sphere
regards,
sphere
2013-03-06, 17:32
This addon is simply wonderful. I came here because I couldn't get the slideshow feature in 3.0.4 to work. 4.0 is fine thankfully! Thanks again for your hard work.
