Neebie here. Can I control volume from a Thunderbolt (Android) running XBMC Remote on a windows 7 PC?
Don't know, but it should be an easy experiment to try ...
JR
Thanks JR - Any recommendations on the experiment?
lol billpratt, I think that jhsrennie meant that you should try it
BTW, I'm not sure what you meant: Do you have XBMC running on a Windows 7 platform and you wish to controll that via an Android device? That's out of the box possible. Volume is changed by the volume buttons of your Thunderbolt.
xburchartz Wrote:lol billpratt, I think that jhsrennie meant that you should try it
Well yes :-)
JR
Just use your volume-buttons...
If you want to change the windows 7 soundlevel you have to use another thing... like GMote.
