Full Version: Trancparency broken in PVR
Trancparency is marked broken in Repository for PVR.
Is there a Way to bring it Up anyway
EDIT:
Oh, sorry, I have better read the Threads
I'll try
=> svn checkout http://transparency-xbmc.googlecode.com/svn/trunk/ skin.transparency
You can disable go to addon.xml is the skin directory and comment out (or remove) that dependency.
I don't use randomitems anyways. This worked for me using neon
issue should be fixed now.
