Full Version: Lost mounted Win7 devices when upgraded to v10.1/2011-03-09
This is probably very easy to fix but I don't know how :o
After upgrading (apt-get update / apt-get install xbmc) to v10.1 my mounted devices SDA1 and SDA3 shows as empty.
Not sure if these pics are of any info?
(http://i55.tinypic.com/2dltd15.png)
(http://i53.tinypic.com/21orgjl.png)
and if i run the mount command from Putty I get following info:
Quote:/dev/sda5 on / type ext3 (rw,errors=remount-ro)
proc on /proc type proc (rw)
none on /sys type sysfs (rw,noexec,nosuid,nodev)
none on /sys/fs/fuse/connections type fusectl (rw)
none on /sys/kernel/debug type debugfs (rw)
none on /sys/kernel/security type securityfs (rw)
udev on /dev type tmpfs (rw,mode=0755)
none on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=0620)
none on /dev/shm type tmpfs (rw,nosuid,nodev)
none on /var/run type tmpfs (rw,nosuid,mode=0755)
none on /var/lock type tmpfs (rw,noexec,nosuid,nodev)
none on /lib/init/rw type tmpfs (rw,nosuid,mode=0755)
/dev/sda1 on /media/04841AC1841AB560 type fuseblk (rw,noexec,nosuid,nodev,allow_other,default_permissions,blksize=4096)
/dev/sda3 on /media/02AE2B02AE2AEE3B type fuseblk (rw,noexec,nosuid,nodev,allow_other,default_permissions,blksize=4096)
The 02AE2B02AE2AEE3B and 04841AC1841AB560 folders contains the data I want to be mounted as before.
Sorry for not having more info, but I'm not sure how to obtain it and what info is needed.
Thanks for any help!
