2011-03-29, 19:49
Pages: 1 2
2011-03-29, 20:00
Log made using Transparancy: http://pastebin.com/K8xNe1pd
Log made using Confluence: http://pastebin.com/2E4hianK
neither skins show the alias/symbolic.
(Sorry for the first log. I use an iMac for regular computing and a Mini as mediaplayer)
2011-03-29, 20:09
same issue under your iMac ?
2011-03-29, 20:24
Same problem (on iMac), they are not visible. Although the log should be identical it is posted here:
http://pastebin.com/gyQuuWj1
The terminal output:
Last login: Tue Mar 29 09:14:48 on ttys000
iMac:~ tonio$ cd /Volumes/TV.Films/00.\ TV\ Opnames
iMac:00. TV Opnames tonio$ ls -la
total 14851376
drwxrwxrwx@ 12 tonio staff 364 29 mrt 14:34 .
drwx------@ 18 tonio staff 568 29 mrt 17:47 ..
-rwxrwxrwx 1 tonio staff 4096 12 mrt 19:58 ._Cover.jpg
-rwxrwxrwx@ 1 tonio staff 122028 28 mrt 17:25 Changeling.mkv alias
lrwxrwxrwx@ 1 tonio staff 49 28 mrt 17:25 Changeling.mkv symlink -> /Volumes/TV.Films/10. Nieuwe Films/Changeling.mkv
-rwxrwxrwx@ 1 tonio staff 16186 12 mrt 19:57 Cover.jpg
-rwxrwxrwx@ 1 tonio staff 5607157760 29 mrt 14:39 Dokument - Paviljoen 7.mpg
drwxrwxrwx@ 10 tonio staff 296 28 mrt 16:32 Human Planet
-rwxrwxrwx@ 1 tonio staff 843205953 18 mrt 20:10 WieisdeMol.m4v
-rwxrwxrwx@ 1 tonio staff 167604 29 mrt 09:12 WieisdeMol.m4v alias
lrwxrwxrwx@ 1 tonio staff 47 29 mrt 09:12 WieisdeMol.m4v symlink -> /Volumes/TV.Films/00. TV Opnames/WieisdeMol.m4v
-rwxrwxrwx@ 1 tonio staff 1152919552 26 feb 22:52 Youp.avi
total 14851376
2011-03-29, 20:37
let's try something simple,
make a dir in your home directory, drop some video in it.
make a symlink in the Desktop folder that points to that dir. In xbmc, browse to it.
2011-03-29, 20:58
I am not sure whether I correctly understood. Did following:
Made a Directory in my Home part, dropped there a movie, made an alias (for symbolic I have to restart my systems and that is not possible for the next hours). So in the Dir there are now 2 files: the movie and an alias to that movie.
Added the Dir to XBMC when navigating to that Dir the movies shows the alias does not.
Last login: Tue Mar 29 20:23:22 on ttys000
iMac:~ tonio$ cd /Users/tonio/naamloze\ map\ 2
iMac:naamloze map 2 tonio$ ls -la
total 1647560
drwxr-xr-x 5 tonio staff 170 29 mrt 20:52 .
drwxr-xr-x@ 73 tonio staff 2482 29 mrt 20:49 ..
-rw-r--r--@ 1 tonio staff 6148 29 mrt 20:48 .DS_Store
-rw-r--r--@ 1 tonio staff 166740 29 mrt 20:52 WieisdeMol.m4v alias
total 1647560
2011-03-30, 00:18
I know this sounds dumb and may not be the answer but it'll kick myself (repeatedly) if I don't mention this:
Have you tried checking the "Show hidden files and directories" tab in the appearance menu of the settings.
Just to see if it has an effect.
Apologies if this was totally retarded to suggest, don't kill me.
2011-03-30, 00:31
Checked it out right away. Alas, does not solve the problem.
(Going to bed now, different time-frame)
2011-03-30, 00:40
Another dumb suggestion - repair permissions?
2011-03-30, 09:46
@davilla:
Put an alias and symbolic in the map. But neither shows.
Screenshot: http://tinypic.com/r/xnw689/7
Last login: Wed Mar 30 08:32:11 on console
iMac:~ tonio$ cd /Users/tonio/Desktop/TestMapXbmc
iMac:TestMapXbmc tonio$ ls -la
total 1647568
drwxr-xr-x 6 tonio staff 204 30 mrt 09:33 .
drwxr-xr-x 14 tonio staff 476 30 mrt 09:32 ..
-rw-r--r--@ 1 tonio staff 166740 30 mrt 09:34 WieisdeMol.m4v alias
lrwxr-xr-x 1 tonio staff 47 30 mrt 09:33 WieisdeMol.m4v symlink -> /Users/tonio/Desktop/TestMapXbmc/WieisdeMol.m4v
total 1647568
2011-03-30, 17:45
Wacky
Anything odd about your OSX setup. Running Case-sensitive filesystem maybe ?
2011-03-30, 18:34
davilla Wrote:Wacky
Not to my knowledge. The Qnap Nas has been default formatted (some EXT-?) and the Mac (that I last used to test) is regularly formatted as journaled. Also no hacks installed. It certainly is not case sensitive
I also tested with Front Row/Sapphire and there the aliased movies are seen. Same for Plex, there the aliased movie is also seen.
Next I have checked Xbmxc using several skins and they all act the same meaning no aliased movies.
Pages: 1 2
