I hope this is the right place for this thread, else i request a moderator to move it ;-)
I'm experiencing that videos played through the youtube addons often run of of video in the buffer, and i have to wait for the buffer til fill up.
I don't experience this when watching the same video through my browser, how come is that?
Is there any settings, buffer size or some where that I can adjust?
I have exactly the same problem. Low bandwidth videos appear to work fine with the youtube add-on, but higher res ones (eg 720p) suffer from regular buffering pauses. Playing the same high-res videos through the browser (chrome) on the same box works perfectly.
I'm running xbmc 10.1 on mythbuntu 10.10 (linux). Xbmc CPU never exceeds 24%.
Xbmc log with debugging enabled:
http://pastebin.com/KpLQbUqC
Can anyone help?
Thanks,
Justin.
Thanks Tobias. I'll give the Eden beta a go.
But one question before I do: From the xbmc log (link pasted in my previous posting), the youtube addon was using the following link:
15:10:38 T:139757359970400 M:3646844928 NOTICE: DVDPlayer: Opening:
http://o-o.preferred.iinet-per1.v19.lsca...outube.com | Mozilla/5.0 (Windows; U; Windows NT 6.1; en-GB; rv:1.9.2.8) Gecko/20100722 Firefox/3.6.8
Is this not a youtube caching server? (FYI iiNet is my ISP here in Perth)
Cheers,
Justin.
jusmop Wrote:Thanks Tobias. I'll give the Eden beta a go.
15:10:38 T:139757359970400 M:3646844928 NOTICE: DVDPlayer: Opening: http://o-o.preferred.iinet-per1.v19.lsca...outube.com | Mozilla/5.0 (Windows; U; Windows NT 6.1; en-GB; rv:1.9.2.8) Gecko/20100722 Firefox/3.6.8
Cheers,
Justin.
Yes that is a caching server. Using the fallback_host will probably work for you(which can be done by toggling "cache" servers in the Eden release).
Hi everyone!
I still have that kind of problem with xbmc Eden and youtube addon . Running on a win7 / 2ghz / 1go pc
There is something i really dont understand, maybe someone had the same issue.
Youtube addon worked perfectly for 2 or 3 days with any kind of video, then i have the pop up message " cache full" and it was over...15m to lauch a video even a small one .
What does that pop up means since we can't clear cache on XBMC? I tried to uninstall/reinstall cache plugin (auto installed with youtube addon), it worked once but the pop up came again...
Hope someone will have an idea
