Hello. In my XBMC I have configured two network interfaces, eth1 and wlan0 with different IP addresses. By default xbmc uses eth1 interface. How I can make using the interface wlan0 xbmc?
Greetings and thank you very much
rodasa Wrote:Hello. In my XBMC I have configured two network interfaces, eth1 and wlan0 with different IP addresses. By default xbmc uses eth1 interface. How I can make using the interface wlan0 xbmc?
Well, we need some more information. Are they static? DHCP? How did you "Configure" it? Encryption? You can try looking in /etc/network/interfaces
put a pound sign in front of these two lines like so
# auto eth0
# iface eth0 inet dhcp
and add pretty much the same thing but witout the pound sign and make it wlan0
auto wlan0
iface wlan0 inet dhcp
if its static you can figure it out quick enough with a google search or even right here on the forums.
auto lo
iface lo inet loopback
auto eth1
iface eth1 inet static
address 192.168.2.99
netmask 255.255.255.0
