2011-03-29, 15:38
Hi, first time posting.
Hopefully someone here might be able to give me some advice. I recently set up a friend's computer (i686) to dual-boot XP and XBMC (10.0 r35648) running over minimal Ubuntu 10.10. The partitions were set up and Ubuntu & Grub2 installed using a LiveCD. XBMC was installed and set up via SVN. I had a few teething troubles at first but managed to get most of the kinks ironed out by looking on this forum. I also managed to get an MCE remote working.
Early on I found I could add the DVD drive as a source by adding "iso9660://" manually but only when a DVD was actually in the drive. I have never been able to find the "cdrom" folder in the file browser or from the Ubuntu command line. XBMC plays movies just fine from any network folder but refuses to load soft subtitles for movies played from the DVD drive regardless of naming convention. When browsing for subtitles manually it finds the folder and subtitle file but clicking on "OK" has absolutely no effect. This occurs on all external subtitle files irrespective of codec or file type.
A less serious issue concerns auto suspend within XBMC. Suspend works briefly but if left too long the mouse stops working. Subsequent suspends last only a fraction of a second before returning to full brightness. I have tried adding a variety of command line fixes but none of them solved this.
simple log report:
http://pastebin.com/2fn2UgxR
and with debugging enabled:
EDIT:
I followed the instructions here:
http://www.linuxconfig.org/HowTo_mount_cdrom_in_linux
and was able to browse contents of a DVD ROM via the command line. However XBMC still refuses to see subtitles within folders on a DVD.
Added mount instructions to /etc/fstab and then eventually gave up and returned it to its original state.
Just added HAL, XBMC no longer exited to command line. I purged and removed it and now the command line appears again!
Installed pmount, XBMC still refuses to load subtitles from DVD folders and I still can't find the DVD in XBMC without typing "iso9660://"
What am I doing wrong?
simple log report:
EDIT:
