I am an XBMC skinning newbie trying to understand the skin views hierarchy.
Looking, for example, on the confluense video-related views. When clicking the video item on the main menu (the log-file shows that) the MyVideoNav.xml is loaded. MyVideoNav.xml's first lines is:
<views>50,51,500,550,560,501,.....</views>
and contains a large number of controls and include statements (that include, among others, the views above spread over multiple files like ViewsFileMode.xml). More than one of these views are list-controls.
How is the layout performed?
How can I determine which is the "root" view?
Which views are shown together to build a more composite view? and which are different screens one on top of the other?
For example, assuming I wanted to change the size of the first list shown (containing "Add Videos..." and "Video Add-ons") - how can identify which is the list currently being shown?
Go to skin folder, open up addon.xml, and make sure you have debugging="true" . This will show you currently focused control.
pecinko Wrote:Go to skin folder, open up addon.xml, and make sure you have debugging="true" . This will show you currently focused control.
Thanks, pecinko! Very helpful. This allows me to learn about the location of buttons, lists, edit, etc.
How can I learn about the layout of other components? For example, the "preview thumbnail" on the bottom right? Also, how can I tell what is the "container" component defining the layout of the various sub-components (e.g. the location of the list in relation to the thumbnail).
pecinko Wrote:Was skinning manual of any help?
http://wiki.xbmc.org/index.php?title=XBM...ing_Manual
Nope. I may have missed it, but I couldn't find anything on the "grand scheme of things". It contains mostly tactical details on controls and their individual configuration. Almost nothing on the layout (outside a list).
Thanks again.
xmichaelm Wrote:Nope. I may have missed it, but I couldn't find anything on the "grand scheme of things". It contains mostly tactical details on controls and their individual configuration. Almost nothing on the layout (outside a list).
Thanks again.
I would recommend downloading skin Foundation, which comes with screenshots of all XBMC windows. Diagram describing their connections does not exist, AFAIK. Still you will learn a great deal from a mentioned skin.
Rule of thumb, that might help you, is that only one control can have focus at a time. Thus, preview thumb, that probably has ListItem.Thumb (or Icon) in code, will show thumb of currently focused item from a focused list.
Thanks again, pecinko.
A trick I found, and that may be useful to others, was to use the skin debugging feature that pecinko suggested, to find the posx and/or posy and look for these coordinates in all the skin xml files (round to 10s and try +10 and -10). This allowed me to located the thumb view under CommonRootView in ViewsFileMode.xml
I had/have great problems navigating skins so let me give you some pointer:
* includes mean you need to have several files open at a time with a lot of searching
* try altering the value of label controls to see what happens
* comment out visible tags to see what happens
* comment out image blocks to see where they are
The big thing I found is that all controls are specified all the time. They are turned on/off with visible tags. Think of them as layers that are enabled through visible tags.
also you need to create a refresh keymap
XBMC.ReloadSkin() works for me anywhere in the skin.
Also, your Keymap.xml goes in AppData\Roaming\XBMC\userdata\keymaps\
PHP Code:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<keymap>
<global>
<keyboard>
<F5>XBMC.ReloadSkin()</F5>
<F7>ShowSubtitles</F7>
<F8>AudioNextLanguage</F8>
</keyboard>
</global>
<MusicInformation>
<keyboard>
<i>Close</i>
</keyboard>
</MusicInformation>
</keymap>
will help alot when skinning sometimes i will disable a button then save and refresh to locate where it is in the skin thats if i cant figure out the code
Thanks hippojay and ZombieRobot - very helpful!
