2013-02-14, 10:50
2013-02-14, 16:41
A full work over would be appreciated thou, since last version, all that worked here was the resent casts.
Top casts, Events and so on gives me a script error, worked well back in eden i remember.
EDIT: I suppose it's the same for all, but if not i can make a log and upload when it should work.
2013-02-17, 02:34
This is a problem with the youtube plugin not the sc2casts plugin. The patch in the following link works if you want it working immediately or you can just wait a few days for them to release an update for the plugin
http://forum.xbmc.org/showthread.php?tid...pid1335605
2013-05-13, 23:41
This addon isn't working at all for me.
Is this still up to date or have you stopped supporting this addon?
thanks,
Neil
thanks,
Neil
2013-11-07, 09:30
Added a fix for the new youtube link. It's a single line change, so if you want to just edit the bsdfish code, you can replace line 161:
with
I've also made my own fork of this since the only updates I've seen to this in over a year are some code formatting changes by retiman (which are incorporated into mine as well)
https://github.com/ekinolik/xbmc-plugin-sc2casts
xbmc-plugin-sc2casts-0.4.7 Download
ideoContent=re.compile('<param name="movie" value="http://www.youtube.com/v/(.+?)\?.+?"></param>').findall(matchCount[i][1])
with
videoContent=re.compile('src="https://www.youtube.com/embed/(.+?)"').findall(matchCount[i][1])
2013-11-07, 09:55
Thanks for the update!
2013-11-25, 04:26
Another update to work with sc2casts updated layout. There's also a fix here that I missed last time so that single game matches will play as well.
Line 170 and 171:
Line 225 - 228
Download xbmc-plugin-sc2casts 0.4.8
Line 170 and 171:
- checkSource = (re.compile('<span class="source_name">(.*?)</span>')
- .findall(link))
+ checkSource = (re.compile('<div class="latest_series" ?>'
+ '<img src=".+?title="(.+?)"').findall(link))
Line 225 - 228
- videoContent=(re.compile('<param name="movie" '
- 'value="%s/v/(.+?)'
- '\?.+?"></param>' % self.VIDEO_URL)
- .findall(link))
+ videoContent=re.compile('src="https://www.youtube.com/embed'
+ '/(.+?)"').findall(link)
2014-01-29, 03:42
(2013-11-25, 04:26)phek Wrote: [ -> ]Another update to work with sc2casts updated layout. There's also a fix here that I missed last time so that single game matches will play as well.
Line 170 and 171:
Code:- checkSource = (re.compile('<span class="source_name">(.*?)</span>')
- .findall(link))
Line 225 - 228
Code:- videoContent=(re.compile('<param name="movie" '
- .findall(link))
http://hackerbot.net/pc/78-starcraft-2-i...and-cheats
new youtube embeds?
2014-01-29, 09:56
been too busy lately to fix whatevers going on with the audio with no video. my guess is that its actually a problem with the youtube plugin since the audio works but like I said, havent had a chance to take a look.
2015-08-22, 11:29
Hi, everybody.
After recent update to Kodi 15.1 (from ancient 13.2 ) SC2casts addon won't work anymore. It shows Youtube error when starting video. kodi log suggests to change syntax of the youtube request. Can anyone please fix the addon? Pretty please!!!!
2015-08-23, 09:38
Hi, @relyter, can you please add the Kodi log part you think suggested that? It can help a lot in fixing the problem
2015-08-23, 12:21
(2015-08-23, 09:38)thatkookooguy Wrote: [ -> ]Hi, @relyter, can you please add the Kodi log part you think suggested that? It can help a lot in fixing the problem
Hi, thatkookooguy. Thank you very much for response.
Historically only the first menu item in the plugin was working i.e. Recent casts. And that what i was trying to fix. Below is the part of kodi log concerning starcraft plugin.
12:01:15 T:4360 NOTICE: -->Python Interpreter Initialized<--
12:01:15 T:4360 NOTICE: SC2Casts-0.4.8
12:01:16 T:3972 NOTICE: Thread BackgroundLoader start, auto delete: false
12:01:17 T:6668 NOTICE: Thread FileCache start, auto delete: false
12:01:17 T:7568 NOTICE: Previous line repeats 2 times.
12:01:17 T:7568 NOTICE: Thread LanguageInvoker start, auto delete: false
12:01:17 T:7568 NOTICE: -->Python Interpreter Initialized<--
12:01:17 T:7568 NOTICE: SC2Casts-0.4.8
12:01:18 T:7560 NOTICE: Thread BackgroundLoader start, auto delete: false
12:01:18 T:5056 NOTICE: Thread FileCache start, auto delete: false
12:01:19 T:6344 NOTICE: Previous line repeats 2 times.
12:01:19 T:6344 NOTICE: Thread LanguageInvoker start, auto delete: false
12:01:19 T:6344 NOTICE: -->Python Interpreter Initialized<--
12:01:19 T:6396 NOTICE: Thread FileCache start, auto delete: false
12:01:19 T:6344 NOTICE: [plugin.video.youtube] Running: YouTube (5.1.7) on Isengard (15.1) with Python 2.7.8
12:01:19 T:6344 WARNING: [plugin.video.youtube] DEPRECATED "plugin://plugin.video.youtube/?action=play_video&videoid=vTDHKLUsOWE?start=0&showinfo=0"
12:01:19 T:6344 WARNING: [plugin.video.youtube] USE INSTEAD "plugin://plugin.video.youtube/play/?video_id=vTDHKLUsOWE?start=0"
12:01:21 T:5208 NOTICE: Thread FileCache start, auto delete: false
12:01:21 T:6344 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.KeyError'>
Error Contents: 'title'
File "D:\XBMC13\portable_data\addons\plugin.video.youtube\default.py", line 7, in <module>
runner.run(__provider__)
File "D:\XBMC13\portable_data\addons\plugin.video.youtube\resources\lib\kodion\runner.py", line 32, in run
__RUNNER__.run(provider, context)
File "D:\XBMC13\portable_data\addons\plugin.video.youtube\resources\lib\kodion\impl\xbmc\xbmc_runner.py", line 23, in run
results = provider.navigate(context)
File "D:\XBMC13\portable_data\addons\plugin.video.youtube\resources\lib\kodion\abstract_provider.py", line 123, in navigate
result = method(context, re_match)
File "D:\XBMC13\portable_data\addons\plugin.video.youtube\resources\lib\kodion\abstract_provider.py", line 157, in _internal_root
return self.on_root(context, re_match)
File "D:\XBMC13\portable_data\addons\plugin.video.youtube\resources\lib\youtube\provider.py", line 485, in on_root
return yt_old_actions.process_old_action(self, context, re_match)
File "D:\XBMC13\portable_data\addons\plugin.video.youtube\resources\lib\youtube\helper\yt_old_actions.py", line 56, in process_old_action
return _process_play_video(provider, context, re_match)
File "D:\XBMC13\portable_data\addons\plugin.video.youtube\resources\lib\youtube\helper\yt_old_actions.py", line 19, in _process_play_video
return provider.on_play(new_context, re_match)
File "D:\XBMC13\portable_data\addons\plugin.video.youtube\resources\lib\kodion\register_provider_path.py", line 12, in wrapper
return func(*args, **kwargs)
File "D:\XBMC13\portable_data\addons\plugin.video.youtube\resources\lib\youtube\provider.py", line 363, in on_play
return yt_play.play_video(self, context, re_match)
File "D:\XBMC13\portable_data\addons\plugin.video.youtube\resources\lib\youtube\helper\yt_play.py", line 17, in play_video
video_streams = client.get_video_streams(context, video_id)
File "D:\XBMC13\portable_data\addons\plugin.video.youtube\resources\lib\youtube\client\youtube.py", line 85, in get_video_streams
video_stream['title'], video_stream['container'], video_stream['video']['encoding'],
KeyError: 'title'
12:01:21 T:3472 NOTICE: Thread FileCache start, auto delete: false
12:01:21 T:2716 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/?action=play_video&videoid=vTDHKLUsOWE?start=0&showinfo=0]
12:01:21 T:1420 NOTICE: Thread BackgroundLoader start, auto delete: false
12:01:21 T:5316 NOTICE: Thread FileCache start, auto delete: false
12:01:23 T:7616 NOTICE: Previous line repeats 3 times.
Well, i tried to change this in sc2casts.py.
Found one enrty, line 133. But there's still an error. Log is below.
12:16:57 T:3920 NOTICE: SC2Casts-0.4.8
12:16:57 T:3908 NOTICE: Thread FileCache start, auto delete: false
12:16:57 T:2620 NOTICE: Thread BackgroundLoader start, auto delete: false
12:16:57 T:6640 NOTICE: Thread FileCache start, auto delete: false
12:17:02 T:1432 NOTICE: Previous line repeats 6 times.
12:17:02 T:1432 NOTICE: Thread LanguageInvoker start, auto delete: false
12:17:03 T:1432 NOTICE: -->Python Interpreter Initialized<--
12:17:03 T:1432 NOTICE: SC2Casts-0.4.8
12:17:04 T:3336 NOTICE: Thread BackgroundLoader start, auto delete: false
12:17:04 T:6344 NOTICE: Thread LanguageInvoker start, auto delete: false
12:17:04 T:6344 NOTICE: -->Python Interpreter Initialized<--
12:17:05 T:6344 NOTICE: [plugin.video.youtube] Running: YouTube (5.1.7) on Isengard (15.1) with Python 2.7.8
12:17:07 T:6344 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
KeyError: 'title'
12:17:07 T:7332 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/play/?video_id=vTDHKLUsOWE?start=0&showinfo=0]
12:17:07 T:7428 NOTICE: Thread BackgroundLoader start, auto delete: false
12:17:08 T:1708 NOTICE: Thread FileCache start, auto delete: false
12:17:09 T:2476 NOTICE: Previous line repeats 1 times.
2015-08-23, 12:27
It's a bug in the youtube addon, that's being adressed by bromix: http://forum.kodi.tv/showthread.php?tid=200735&page=151
