2011-03-30, 17:36
When XBMC is used with Nvidia hardware, tearing will occur when the X composite extension is used.
Solution 1: (thanks to chessplayer for pointing this out)
Enable "Unredirect Fullscreen Window" in Compiz Config Settings Manager.
An easy solution for this is described in the following thread on ubuntuforums.org. This is actually quite easy.
In short, what must be done is
For Ubuntu, this option is found in the "General" section of CCSM until 10.10 (Maverick). In Natty (due to Unity), it has been moved to the "Composite" section.
Solution 2:
Disable the composite extension.
Add this to the end of /etc/X11/xorg.conf: (make a new file if xorg.conf doesn't exist)
Then log in with a gnome classic session (without the composite extension compiz doesn't work).
Also make sure to set Vertical blank sync to Always enabled in XBMC.
Solution 3:
Disable the use of the SDL backing store - this is a bug in Ubuntu which will probably be fixed in due time but could cause tearing right now:
Solution can be found here: http://askubuntu.com/questions/450593/ho...673#450673
See http://forum.xbmc.org/showthread.php?tid=190655
- Install CCSM (Compiz Config Settings Manager)
Code:sudo apt-get install compizconfig-settings-manager
- Check the option "Unredirect Fullscreen Window"
Solution 2:
Section "Extensions"
Option "Composite" "Disable"
EndSection
Solution 3:
