Full Version: Iphone worked EVO does not
Just switch from Iphone to Evo 4G.
Using the same exact settings from Iphone and keeps saying username/password incorrect.
Checked again with Iphone, Iphone works perfectly.
Changed password on xbmc, Retried Iphone works EVO does not same error.
Any ideas?
Something went wrong with my Evo. I had mine working perfectly on multiple boxes. I hadn't used it in a while then went to try it at work with XBMC installed on a netbook using my hotspot for the connection (no infrastructure, no ad-hoc on android) about a month ago. Most of the functions no longer worked. To be sure I hadn't messed anything up with that hotspot trick, I used my old HTC Hero, same result. I tried it again a few days ago with my HTPC, now, I can't connect at all.
@whatswrong: If it tells you the username/password is incorrect it means ... you can guess Wink
Try disabling un and pw and retry.
