Full Version: No default Fanart/Miniature.
This question probably has risen before but I cannot find it. So please can someone point me to the correct place.
My problem/questions is that sometimes there no Fanart/Miniature can be found. In those cases I would like to provide my own Miniature and/or Fanart. However I cannot find how to do that.
Is this problem solved in some other thread, do I need a plugin or ..........?
If it is scraping then you could always upload your fan art to the scraper so others may use it.
http://www.themoviedb.org
or
http://www.thetvdb.org
However I couldn't find it but, you can put the image in the folder of the item and call that image "fanart.jpg" (or tbn etc) and it will use it. I think. Closest article is:
http://wiki.xbmc.org/index.php?title=Thumbnails
Thanks for the help. Solved my problem.
