have you had a chance to look at the json response issue in b2 and later?
I Haven't had time to do anything with this the past few weeks. Over the holidays I plan to install a Frodo RC and update this program to handle the JSON-RPC changes.
(2012-12-21, 16:18)bradvido88 Wrote: [ -> ]XBMC.MyLibrary 1.4.3
Posted a new build with bug fixes (including fixing the broken JSON-RPC int runtime parameter).
This build tested against XBMC Frodo RC2.
Download here: http://code.google.com/p/xbmc-mylibrary/downloads/list
Thank you, I ended up downloading it earlier this morning, everything worked like a champ.
hi
does the new version support non english letters?
can i use the plug in to retrieve strm channels of israeli websites?
if you can remember, i sent you a few print screens on this before
thanks
For whatever reason, MyLibrary is not removing files that are no longer present on websites (Hulu, specifically). I have went through the Config file, and everything seems correct. Anyone have any tips on this, or something in particular I should look for?
(2013-01-05, 03:01)binarybomber Wrote: [ -> ]For whatever reason, MyLibrary is not removing files that are no longer present on websites (Hulu, specifically). I have went through the Config file, and everything seems correct. Anyone have any tips on this, or something in particular I should look for?
What thresholds do you have defined for cleanup in your config? A log would be useful.
Thresholds are now set to:
(manual archiving)
<HoursThreshold>1.0</HoursThreshold>
(video cleanup)
<ConsecutiveThreshold>2</ConsecutiveThreshold>
I just changed the manual archiving threshold to 1 hr, so let me re-run the scan and see what happens. If it doesn't help, I'll see if I can get a log posted. Thanks BradVido88!
Hi
does the new versions support non english languages?
can i use it to scrape israeli plugins where the title of the show and episode are in hebrew?
previous version did not allow me to scrape
thanks
bradvido88: still love this tool, thanks for continuing to maintain and develop it. Obviously, the point of every complement is to grease the skids of a request, so here it goes.
1) I know the config file has the ability to allow xml based exclusions. Some streaming services (like HBO and Crackle) update their available movies every week, and I would like to be able to remove the movies that are duplicates of locally stored movies (at least, until XBMC implements a movie duplicated stacking mechanism like plex). Would it be possible to either dynamically generate the exclusion list based on current library content and/or to read the current XBMC library database to exclude items that I have stored locally? I have considered adding the movie items manually, but I have ~1500 movies stored locally, and the count changes fairly often as I add new items so this would be quite an arduous and manual process. Alternatively, it might be easier to "teach" xbmc.mylibrary to parse an xml export of the xbmc database that could still be done manually...
2) Is there a way to prevent the xbmc.mylibrary code from deleting the fanart folders in my movie/tv show drop boxes? These fanart folders aren't empty, but don't contain .strm files, so they get removed. I understand the purpose and like the feature of cleaning up empty folders, but I use the artwork downloader to populate extra fanart folders in each movie/tv show folder and these tend to get deleted because there are no stream files in them.
Thanks again for developing xbmc.mylibrary - it's really a slick idea.
Loving the addon but having a problem with getting it to working. I'm using XBMCUBUNTU with Eden and I've got it where its accessing the DBs but only if I use raw. Doing that I'm not getting anything and I'd like to use http as it seems to work so much better for everyone but I'm not sure why its generating json errors when I run the script. I figure I'm probably missing something but when I installed firefox thinking it might be due to a lack of a browser this didn't resolve it. Anyone have any ideas?
Has anyone got this successfully working with XBMCFlicks? I definitely can't pay for PlayOn just to get Netflix shows into my library. Please give me a shout out if anyone at all as ever got this working this way.
Search results.
I had commented on this, so I knew it had come up before. Searching 'xbmcflicks' also has results of a user switching to playon because of problems with xbmcflicks though.
I have MyLibrary working great for the examples in the config file.
I'm trying to get it to work with PlexBMC but I get errors.
http://pastebin.com/pZe0wQ6E
I posted the entire debug log but the error is "Could not get valid XML data from URL" with an invalid argument exception.
