Full Version: XBMC.MyLibrary - Scan any source to the library (Hulu/Netflix/Plugins)
I just started using this addon (Great addon by the way). I have been seeing the following when it is parsing the Amazon plugin: and it flags these as invalid and doesn't put them into the xbmc library
02/03/2013 10:12:56 AM INFO SxEx Duplicate This TV Show is already archived
(based on Season/Episode numbers) at: "\\192.168.1.91\E\STRM\TV Shows\Season.1.
[COLOR.FFE47911][HD][COLOR]\Season.1\S01E19 - Let Bartlet be Bartlet.strm", will
not archive again: Amazon/Television/HDTV Shows/Storage Wars/Season 1 [COLOR FF
E47911][HD][COLOR]/1x19 - Live and Let Bid
02/03/2013 10:12:57 AM INFO Archiving This label contains a '/', will
remove it because it is reserved: "Season 2 [COLOR FFE47911][HD][/COLOR]"
can the parser remove the "[COLOR FFE47911][HD][/COLOR]" ?
(2013-02-03, 18:15)carl1jenn Wrote: [ -> ]I just started using this addon (Great addon by the way). I have been seeing the following when it is parsing the Amazon plugin: and it flags these as invalid and doesn't put them into the xbmc library
Getting the same here. I added it to my advancedsettings.xml as an regexp so the scraper ignores it. Works on some but not all. Definitely needs to be addressed on this end.
How did you modify your advancedsettings.xml? Some shows working is better than none.
I haven't noticed that problem with the Amazon add-on. It looks like a bug with the Amazon add-on itself or possibly the JSON-RPC interface should not return color tags when asking for the label. Either way, i dont think the problem is here.
Is it with all shows or just a few?
Thank you very much bradvido88. Your tool is working wonderfully. Below are some things I noticed:
- For one movie "The Chronicles of Narnia: The Lion, the Witch and the Wardrobe" I got three entries in my library, each with a slight variation in the title.
- I'm using extrathumbs (thumb1.jpg etc.) and these got scraped as movies. I know you can filter them out, but it would be nice to have this by default.
- It seems that the extrathumbs are not not scraped (like they should). The extrathumbs placeholders in the Multiplex view are empty.
- I noticed that iso files are not scraped. It may be that XBMC doesn't scrape these at all, I'm not sure.
- This is more of a question: I have .nfo files named movie.nfo. Are these scraped or is all info scraped from TMDB?
Some of these problems may be cause by me, or by XBMC itself. But I figured it was easy to post some comments here.
That is all for now. Thanks again!
Bradvido88 - I believe it is with most shows - amazon seems to be color coding their HD shows.
Just started using this addon recently and its working pretty well on the few shows I've tried to add except one that I'm struggling with. I'm trying to add Conan via the FreeCable addon but it exports out to date based strm files which the scraper doesn't seem to parse properly. I found a previous post for the same issue, though using PlayOn vs FreeCable, but I believe the problem is the same. Was a workaround ever found for this? Here is my entry in the config file:
        <FreeCable path="plugin://plugin.video.free.cable" recursive="true" prefix="(F) " >
            <subfolder name="TBS/Full Episodes/Conan" type="episodes" >
                <filter>
                </filter>
            </subfolder>
        </FreeCable>
(2013-02-04, 23:18)bradvido88 Wrote: [ -> ]I haven't noticed that problem with the Amazon add-on. It looks like a bug with the Amazon add-on itself or possibly the JSON-RPC interface should not return color tags when asking for the label. Either way, i dont think the problem is here.
Definitely on all HD shows.
<video>
<cleanstrings action="prepend">
<regexp>season[. _]\d+$</regexp>
<regexp>[ _\,\.\(\)\[\]\-](COLOR|FFE47911|HD|ac3|dts|custom|dc|divx|divx5|dsr|dsrip|dutch|dvd|dvdrip|dvdscr|dvdscreener|screener|dvdivx|cam|fragment|fs|hdtv|hdrip|hdtvrip|internal|limited|multisubs|ntsc|ogg|ogm|pal|pdtv|proper|repack|rerip|retail|r3|r5|bd5|se|svcd|swedish|german|read.nfo|nfofix|unrated|ws|telesync|ts|telecine|tc|brrip|bdrip|480p|480i|576p|576i|720p|720i|1080p|1080i|hrhd|hrhdtv|hddvd|bluray|x264|h264|xvid|xvidvd|DOM|www.www|cd[1-9]|\[.*\])([ _\,\.\(\)\[\]\-]|$)
</regexp>
<regexp>(\[.*\])
</regexp>
</cleanstrings>
</video>
Quote:<regexp>season[. _]\d+$</regexp>
[/code]was suggested to me to clean off the .season#. Got most of the rest from the xbmc wiki. I added the color, code, and HD.
hi
is there a way to scrap everything under a folder and throw it in a folder without thetvdb lookup?
under pbs kids there are a lot of seseme street clips or mtv shows.
i just want them all being thrown in a folder called pbs kids or mtv. i tried using the generic type (and created a generic folder) but it doesnt do anything other than delete all the folders in my dropbox folder)
this is for psuedo tv use
any idea?
thanks
I added this entry into my advancedsettings.xml and then reran the xbmclibrary with run-x64.cmd but i checked my info.log and seems it still saw the [color] stuff coming from the amazon plugin: Did I put the cleanstrings in the wrong place in advancedsettings.xml? thank you for your help.
02/07/2013 07:10:34 AM INFO Find:Subfolder Searching for subfolder: Amazon/Television/HDTV Shows
02/07/2013 07:10:42 AM NOTICE Found! Amazon's subfolder "Amazon/Television/HDTV Shows" maps to source: plugin://plugin.video.amazon/?url=""&mode="listtv"&sitemode="LIST_HDTVSHOWS"&name="HDTV+Shows"&page="1" (Amazon/Television/HDTV Shows)
02/07/2013 07:10:44 AM INFO Search:Amazon Found 4445 videos that are already archived in dropbox from source "Amazon"
02/07/2013 07:10:44 AM NOTICE Search:Amazon Finding all matching videos under subfolder: Amazon/Television/HDTV Shows
02/07/2013 07:10:45 AM INFO Archiving This label contains a '/', will remove it because it is reserved: "Season 2 [COLOR FFE47911][HD][/COLOR]"
02/07/2013 07:10:45 AM INFO Archiving This label contains a '/', will remove it because it is reserved: "Season 1 [COLOR FFE47911][HD][/COLOR]"
02/07/2013 07:10:48 AM INFO SxEx Duplicate This TV Show is already archived (based on Season/Episode numbers) at: "\\192.168.1.91\E\STRM\TV Shows\Season.2.[COLOR.FFE47911][HD][COLOR]\Season.2\S02E00 - Season 1 Recap, Pt. A.strm", will not archive again: Amazon/Television/HDTV Shows/Masterpiece: Downton Abbey/Season 2 [COLOR FFE47911][HD][COLOR]/2x0 - Downton Abbey, A House in History
02/07/2013 07:10:48 AM INFO SxEx Duplicate This TV Show is already archived (based on Season/Episode numbers) at: "\\192.168.1.91\E\STRM\TV Shows\Season.2.[COLOR.FFE47911][HD][COLOR]\Season.2\S02E01 - Bzzzzzzzzz!.strm", will not archive again: Amazon/Television/HDTV Shows/Masterpiece: Downton Abbey/Season 2 [COLOR FFE47911][HD][COLOR]/2x1 - Original UK Version Episode 1 Part One
02/07/2013 07:10:48 AM INFO SxEx Duplicate This TV Show is already archived (based on Season/Episode numbers) at: "\\192.168.1.91\E\STRM\TV Shows\Season.2.[COLOR.FFE47911][HD][COLOR]\Season.2\S02E02 - Circus Circus.strm", will not archive again: Amazon/Television/HDTV Shows/Masterpiece: Downton Abbey/Season 2 [COLOR FFE47911][HD][COLOR]/2x2 - Original UK Version Part Two
02/07/2013 07:10:48 AM INFO SxEx Duplicate This TV Show is already archived (based on Season/Episode numbers) at: "\\192.168.1.91\E\STRM\TV Shows\Season.2.[COLOR.FFE47911][HD][COLOR]\Season.2\S02E03 - Bad Habits.strm", will not archive again: Amazon/Television/HDTV Shows/Masterpiece: Downton Abbey/Season 2 [COLOR FFE47911][HD][COLOR]/2x3 - Original UK Version Part Three
02/07/2013 07:10:48 AM INFO SxEx Duplicate This TV Show is already archived (based on Season/Episode numbers) at: "\\192.168.1.91\E\STRM\TV Shows\Season.2.[COLOR.FFE47911][HD][COLOR]\Season.2\S02E04 - Frescorts.strm", will not archive again: Amazon/Television/HDTV Shows/Masterpiece: Downton Abbey/Season 2 [COLOR FFE47911][HD][COLOR]/2x4 - Original UK Version Part Four
02/07/2013 07:10:48 AM INFO SxEx Duplicate This TV Show is already archived (based on Season/Episode numbers) at: "\\192.168.1.91\E\STRM\TV Shows\Season.2.[COLOR.FFE47911][HD][COLOR]\Season.2\S02E05 - Dim Sum Lose Some.strm", will not archive again: Amazon/Television/HDTV Shows/Masterpiece: Downton Abbey/Season 2 [COLOR FFE47911][HD][COLOR]/2x5 - Original UK Version Part Five
02/07/2013 07:10:48 AM INFO SxEx Duplicate This TV Show is already archived (based on Season/Episode numbers) at: "\\192.168.1.91\E\STRM\TV Shows\Season.2.[COLOR.FFE47911][HD][COLOR]\Season.2\S02E06 - Oh Oh Oh...It's Magic.strm", will not archive again: Amazon/Television/HDTV Shows/Masterpiece: Downton Abbey/Season 2 [COLOR FFE47911][HD][COLOR]/2x6 - Original UK Version Part Six
02/07/2013 07:10:48 AM INFO SxEx Duplicate This TV Show is already archived (based on Season/Episode numbers) at: "\\192.168.1.91\E\STRM\TV Shows\Season.2.[COLOR.FFE47911][HD][COLOR]\Season.2\S02E07 - Robbing Hood.strm", will not archive again: Amazon/Television/HDTV Shows/Masterpiece: Downton Abbey/Season 2 [COLOR FFE47911][HD][COLOR]/2x7 - Original UK Version Part Seven
02/07/2013 07:10:48 AM INFO SxEx Duplicate This TV Show is already archived (based on Season/Episode numbers) at: "\\192.168.1.91\E\STRM\TV Shows\Season.2.[COLOR.FFE47911][HD][COLOR]\Season.2\S02E08 - Comfort Food.strm", will not archive again: Amazon/Television/HDTV Shows/Masterpiece: Downton Abbey/Season 2 [COLOR FFE47911][HD][COLOR]/2x8 - Original UK Version Part Eight
(2013-02-07, 13:48)EZ1976 Wrote: [ -> ]hi
any idea?
thanks
Did you change the runtime filter so it could pick up shorter clips? I too would like to know if people have used this to scrape full length tv episodes(that don't match tvdb)using a generic filter. I have tried but get no results as well.
So I tried making a UPNP scraper filter for my Windows Media Center. I got the server working in my videos, and I got the xml file to see the source, however it can't find the subfolder. It's using the filter path(DVR) as part of the subfolder address(DVR/Public/Recorded TV/Series/). I tried to work around this by naming the filter WINSERVER but that didn't work. I don't know if I need the include the full path(C:/....), but the fact that it is including the filter name in the subfolder makes me thin it wouldn't matter.
Is this even possible to do?
Hi All,
I am trying to configure the my.library utility for use with PlayOn (Hulu/Netflix), in an effort to save some time is any body willing to share their conflig.xml and the associated search filters for PlayOn?
Any help would be choice.
Cheers.
(2013-02-08, 03:43)chan069 Wrote: [ -> ]Hi All,
Cheers.
Look about three pages back for my Netflix. Hulu would run similar. Have to figure out the correct paths to what you want.
Ry
It seems that what worked in Eden to clean up the Amazon HD entries does not work in Frodo.
<video>
</cleanstrings>
</video>
to
<video>
<cleanstrings action="append">
</cleanstrings>
</video>
Frodo seems to like the append better than the prepend. It is even clipping off the HD and Color stuff.
