Experiencing the same issue. The INFO.log shows Archive:New but then proceeds to Clean Up. When setting the config to ManualArchive="true" the INFO.log seems to suggest that XBMC is having issues scraping the show.
INFO ManualArchive Could not find corresponding original video that was archived at: \\pillbox\videos\TV Shows\Marvel's.Agents.of.S.H.I.E.L.D\Season.0\S00E01 - FZZT.strm. Will attempt secondary method. This usually means the original source that created this video no longer exists.
WARN ManualArchive No video found in the database using SQL: SELECT original_path, dropbox_location, video_type, title, series, artist, episode_number, season_number, year, is_tvdb_lookup FROM ArchivedFiles WHERE dropbox_location = ?
WARN ManualArchive Failed to get meta-data for this video. It will be deleted since it was not scraped by XBMC and cannot be manually archived: \\pillbox\videos\TV Shows\Marvel's.Agents.of.S.H.I.E.L.D\Season.0\S00E01 - FZZT.strm
INFO ManualArchive Could not find corresponding original video that was archived at: \\pillbox\videos\TV Shows\Marvel's.Agents.of.S.H.I.E.L.D\Season.1\S01E05 - title.strm. Will attempt secondary method. This usually means the original source that created this video no longer exists.
WARN ManualArchive Failed to get meta-data for this video. It will be deleted since it was not scraped by XBMC and cannot be manually archived: \\pillbox\videos\TV Shows\Marvel's.Agents.of.S.H.I.E.L.D\Season.1\S01E05 - title.strm
INFO ManualArchive Could not find corresponding original video that was archived at: \\pillbox\videos\TV Shows\Marvel's.Agents.of.S.H.I.E.L.D\Season.1\S01E08 - title.strm. Will attempt secondary method. This usually means the original source that created this video no longer exists.
WARN ManualArchive Failed to get meta-data for this video. It will be deleted since it was not scraped by XBMC and cannot be manually archived: \\pillbox\videos\TV Shows\Marvel's.Agents.of.S.H.I.E.L.D\Season.1\S01E08 - title.strm
INFO ManualArchive Could not find corresponding original video that was archived at: \\pillbox\videos\TV Shows\Marvel's.Agents.of.S.H.I.E.L.D\Season.1\S01E09 - title.strm. Will attempt secondary method. This usually means the original source that created this video no longer exists.
WARN ManualArchive Failed to get meta-data for this video. It will be deleted since it was not scraped by XBMC and cannot be manually archived: \\pillbox\videos\TV Shows\Marvel's.Agents.of.S.H.I.E.L.D\Season.1\S01E09 - title.strm
INFO ManualArchive Could not find corresponding original video that was archived at: \\pillbox\videos\TV Shows\Marvel's.Agents.of.S.H.I.E.L.D\Season.1\S01E10 - title.strm. Will attempt secondary method. This usually means the original source that created this video no longer exists.
WARN ManualArchive Failed to get meta-data for this video. It will be deleted since it was not scraped by XBMC and cannot be manually archived: \\pillbox\videos\TV Shows\Marvel's.Agents.of.S.H.I.E.L.D\Season.1\S01E10 - title.strm
