2011-04-01, 06:42
2011-04-01, 13:29
tpunder Wrote:Is there a downloader for tvtunes built into the skin? I can't seem to find it. Thanks for all of your hard work.
TV tunes itself has a downloader built in.
2011-04-01, 19:30
stoli Wrote:TV tunes itself has a downloader built in.
Great! Where? I'm apparently missing the obvious.
2011-04-01, 19:45
tpunder Wrote:Great! Where? I'm apparently missing the obvious.
Video > Addons > TVTunes > Press enter.
Done.
2011-04-02, 02:18
Ah ha! Thanks, I don't usually go into Videos that often, usually use the library options.
2011-04-05, 14:39
Of course add-ons can also be accessed by going into system/settings as well.
or having it as a main button on the home window in most if not all skins.
TC
TC
2011-04-05, 22:06
tcman47 Wrote:Of course add-ons can also be accessed by going into system/settings as well.
TC
Yea I had tried those, the Addons option off the main screen doesn't list TvTunes, just the RSS Editor. In System/Settings I don't think I ever just hit enter on it, usually brought up the context menu.
2011-04-05, 22:11
you'll find it in videos addons.
maybe i should put it on program addons ? don't know what the best .
2011-04-06, 06:24
It's probably fine in Video/Addons, I just don't go into there very often since I use library mode so it didn't occur to me to look there. Although, if it were available on the home screen addons menu that might save someone else the same confusion I had. Either way, this thread is around now so the information is out there. Thanks!
2011-04-28, 05:41
where is the setting in neon. Cant get this to work on my atv2 using smb.
2011-04-28, 05:48
rflores2323 Wrote:where is the setting in neon. Cant get this to work on my atv2 using smb.
stoli Wrote:Video > Addons > TVTunes > Press enter.
Done.
Was posted above
2011-04-28, 06:25
ThY91 Wrote:Was posted above
Doesnt start when i go to my tv shows. I ran script and tried to download however since im on atv2 it doesnt download. I did run the script on my htpc which has my tv show folders. It doesnt start on the atv2,though.
