2011-04-05, 11:50
Hi. I am building a HTPC for a friend for the first time. I have put together a spec and would really appreiciate your opinions on the combination of parts.
Requirements are as follows:
My friend has chosen his preferred case, and the TV-tuner card seems to be practically the only option when it comes to dual tuner HD cards. The spec I have proposed is as follows:
S10v case
BlackGold BGT3620 Tv Card
Asus P8H67-M R3.0 Motherboard
Intel Core i3 2120 3.3GHz Processor
Corsair 4GB DDR3 1333MHz RAM
Corsair 120GB Force SSD
Antec 380W EarthWatts Green Power Supply
Windows 7 Home Premium 64bit with a probable dual-boot with XBMC
Sandybridge should do the trick performance-wise, and USB-3 should help file transfer speeds from external drives. The stock CPU fan should be fine in Auto-mode, the PSU is quiet, and I can under-volt the case fans if necessary but i cant imagine it will run very hot anyway.
All together it is going to cost around £1100 (expensive case!).
What are your thoughts? Have i missed anything that would be a better fit? Many thanks.
- As quiet as possible
- Ability to watch and record HD simultaneously
- Make use of external storage and blue-ray drive
- Fairly future-proof
S10v case
