othrayte Wrote:The underlying problem is this error "AttributeError: 'module' object has no attribute 'JSONDecodeError'", you can follow our progress to fix it here.
Thanks for reporting it.
oh, i see. i hope the issue gets fixed soon.
Can't download this - all links 404.
Thatgrumguy Wrote:Can't download this - all links 404.
Could you please try to download it again now, I was able to download v0.6.0 from the download page, maybe it was a temporary problem. If you are still unable to download it then could you please provide some steps to reproduce the error.
just so you know.. i got "invalid password or username" when i had a password with special characters like "&" and such
ok for some reason trakt utilities does not popup the rating system at the end of a show or movie. See log below. It now does startup however there is a notificatoin sating cannot connect to server.
see log here
http://paste2.org/p/1594279
Mac OS X (11.0.0 AppleTV2,1). Built on Jun 23 2011 (Git:20110623-62171b3)
can any one confirm this is working with latest nightly as when i press sync either library it just hangs
The trakt utilities plugin is not working correctly for me. I have 143 movies in my XBMC library, but the plugin only found 33. He did find all the tv show episodes in the correct amount.
I used the update movie collection button, and after i deleted a few episodes the clean tv show collection, but they don't seem to be working. I posted a log at the bottom of my post that contains all errors.
I am using XBMC Eden latest edition (22-08-2011), with skin XeeBo. All my movies are scrapped using tmdb.
https://docs.google.com/leaf?id=0Bx5vBG8...YmNi&hl=nl
Firstly, I should be catching up with and fixing all of your issues that I haven't been able to deal with yet over the next few days.
dunpealhunter, not certain why but I'm unable to access that log file, could you please upload it to somewhere like ge.tt our pm it to me.
FrenZee, I'll check the latest nightly of XBMC soon, so far I've tested up to 17/8 and it had worked so far.
@rflores, should get a chance to check very soon.
Thorbear, should get a chance to check both of your reports by tomorrow.
Thatgrumguy, haven't heard back from you, have we fixed the problem for you?
Shinu, I'm still working on the JSON related issues, hopefully they will be fixed soon.
@Machine-Sanctum, does it work with newer nightlies, I haven't had any problems with 17/8?
If I have missed someones issue here, don't worry I'll be looking back through the forum to make sure that I haven't missed any when I deal with these ones.
Also this will probably be the push to get v0.6.1 completed.
dunpealhunter Wrote:The trakt utilities plugin is not working correctly for me. I have 143 movies in my XBMC library, but the plugin only found 33. He did find all the tv show episodes in the correct amount.
Thanks for sending me that log. I've had a preliminary look and it appears like you might need to change your username in TU to 'dunpealhunter' as opposed to your email address, now this is only a preliminary idea but its worth a shot until I have time to really investigate properly.
I did that, but it didn't help. Also it seems that new movies are being scrapped to my collection. Yesterday i downloaded Fast Five and it got added.
othrayte Wrote:Firstly, I should be catching up with and fixing all of your issues that I haven't been able to deal with yet over the next few days.
Running nightly from aug 23. So far no real problems. Although the problem of shutting down XBMC still remains. It just hangs or take a ver very long time (sometime up to 10 min or so). Promised you my log file and i forgot
Will get into that.
Does TU still require the official Trakt add-on? I also posted my problem there and they said it i didn't need it if i'm using TU.
http://forum.xbmc.org/showpost.php?p=862...count=1142
Haven't tried deinstalling yet. I did disable their auto submit (one week ago i think).
The other things is that sometimes i get the message autoexec.py failed and if i can remember correctly it doesn't update my watching/watched status automaticly anymore since 2 or 3 days.
Could you make an option to hide the message pop-ups (sync and update etc..)?
EDIT:
Here the debug log. It definitly hangs when i enable trakt auto submit (as you can see from the log)
http://pastebin.com/TuSRL6ye
Tried to disable the official trakt but after restart xbmc totally crashes. To enable trakt again you have to act very fast before it crashes again. Maybe make a safty option (if trakt it still needed) to first chech if it's installed/enable or else terminate TU and display message to install trakt.
rflores2323 Wrote:ok for some reason trakt utilities does not popup the rating system at the end of a show or movie. See log below. It now does startup however there is a notificatoin sating cannot connect to server.
see log here http://paste2.org/p/1594279
Ditto on this. Same error. Same build.
I am also experiencing the shutdown hang issue :-(
I made an issue on the tracker:
https://github.com/Manromen/script.Trakt.../issues/89
Probably this is already reported and needs deleting?
Many thanks,
Mark
***P.S. One thing that I'd really like to see is a way to fire off the sync / clean etc part of the script every x minutes (Or even better, on library update), I have Sickbeard and Couchpotato adding to my library and hence XBMC very rarely gets shut down... This would be a great help***
dunpealhunter Wrote:I did that, but it didn't help. Also it seems that new movies are being scrapped to my collection. Yesterday i downloaded Fast Five and it got added.
I've had a report from someone else that the problem your describing of some not being added can occur if there is a watched status (on trakt) i think, I'm going to investigate this further as
this issue on github. Does this make sense with what you are seeing?
