2011-05-09, 15:01
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103
2011-05-09, 15:29
Well I don't have the time to make a video, but here are some images that I prepared earlier.
Rating an episode
After clicking on 'Rate Show'
Rating a show
After rating show
Back to rate episode
The movie rating dialog looks the same but the 'rate show' button is hidden (obviously).
So that is what they look like now, but I'm working on some changes for 0.5.2 that will add more features to that dialog, so I'm in the process of reworking it at the moment; I'll add screenshots of that when we release 0.5.2 (unless I forget ).
Rating an episode
Rating a show
After rating show
2011-05-09, 19:08
othrayte Wrote:Well I don't have the time to make a video, but here are some images that I prepared earlier.
Rating an episode
Rating a show
After rating show
Looks great. would love to see a video of this in action, even a phone camera video would be great.. Also does it have to end the show/movie completely for this to pop up? Or is there a limit of 80% to 90% of the movie watched then if you click on exit this would pop up? Since I dont want to sit thru the credit to rate the show at the end.
2011-05-09, 19:17
rflores2323 Wrote:Looks great. would love to see a video of this in action, even a phone camera video would be great.. Also does it have to end the show/movie completely for this to pop up? Or is there a limit of 80% to 90% of the movie watched then if you click on exit this would pop up? Since I dont want to sit thru the credit to rate the show at the end.
Thanks, if I find some time I'll try to make a video, but it might be while till I can.
No you don't have to wait to the end, current it pops up if you watch the item for at least half of the time it goes for. Most people would call this half way, but you actually have to watch 45mins of a 1.5hr movie, it doesn't actually care what 45mins you watch, you could theoretically watch the same 1min 45 times .
At the moment it is quite arbitrary, its just the value I wrote in when I was implementing it, I'm open for suggestions (and justifications) for what the required percentage viewed should be, or do you want an option for it.
2011-05-09, 19:21
othrayte Wrote:Thanks, if I find some time I'll try to make a video, but it might be while till I can.Thanks for the reply.
I would think the below two options would work
1. user able to chose what percentage you want the popup to start at 75% to 95%.
2. able to bring up in the context menu or movie information screen to be able to rate movies.
2011-05-09, 20:06
rflores2323 Wrote:Thanks for the reply.
I have added a issue (feature) that should see the option included in v0.6.0
Afaik the person writing the skin has control over the information screen, so we (the plugin) have little or no ability to add a hook there, but I might consider at some point making it possible for a skinner to add such a hook to bring up a rating dialog, I believe it is the same for the context menu. We do plan to allow you to change ratings from within any item list in the plugin, so the watch-list, recommended list etc (maybe soon even a list of your collection). It would certainly be nice from a plugin developers point of view to be able to add items to the context menus in the library for instance, but alas what you don't do yourself often doesn't happen .
2011-05-11, 06:15
I've installed trakt utility to try sync my movie and tv show's database, but the script says that doesn't have nothing to sync.
Anyone knows if the problem could be my "MySQL" database or would it be working anyway?
2011-05-11, 07:36
MySQL should work fine.
What versions are you trying? (xbmc, script)
You could enable debug mode for trakt utilities (in addon settings) and give me a log (pastebin.com).
Maybe I can see something there.
2011-05-11, 14:44
Here is the logFile.
I'm having problem with TvShows too, see the end of file.
About the movies, it mens that should I be using IMDB instead of TheMovieDB?
Quote:09:32:30 T:4068 M:1341820928 NOTICE: -->Python Interpreter Initialized<--
09:32:31 T:4068 M:1339080704 NOTICE: Trakt Utilities: default: script.TraktUtilities - version: 0.5.1
09:32:34 T:4068 M:1339154432 NOTICE: Trakt Utilities: Select: 4
09:32:37 T:4068 M:1340227584 NOTICE: Trakt Utilities: Select: 0
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Splice - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping The Town - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Se7en - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping The Social Network - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Unstoppable - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Harry Potter and the Chamber Of Secrets - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Welcome to the Rileys - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Conviction - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Dinner for Schmucks - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping RED - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Secretariat - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Skyline - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Ticking Clock - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Twelve - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping A Nightmare on Elm Street - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Cyrus - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Never Let Me Go - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping The Last Exorcism - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Going the Distance - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping It's Kind of a Funny Story - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Love and Other Drugs - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Life as We Know It - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping You Will Meet a Tall Dark Stranger - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping The Resident - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Elite Squad 2 - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Ice Age 3: Dawn of the Dinosaurs - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Harry Potter and the Order of the Phoenix - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Kong Zi - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping 127 Hours - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Cars - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping The Big Bang - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping The Sunset Limited - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping The Tourist - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Harry Potter and the Prisoner of Azkaban - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping The Reef - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping The King's Speech - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Tron Legacy - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping The Matrix Revolutions - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping The Matrix - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping The Matrix Reloaded - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping The Fighter - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Black Swan - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Cougars, Inc. - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Eric and Ernie - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Harry Potter and the Deathly Hallows: Part I - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Hereafter - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Last Night - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Little Fockers - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping The Chronicles of Narnia: The Voyage of the Dawn Treader - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Harry Potter and the Goblet of Fire - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Your Love Never Fails - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping A Beautiful Mind - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Due Date - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Fair Game - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Jack Falls - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping London Boulevard - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping The Way Back - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping How Do You Know - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping No Strings Attached - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Sanctum - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Country Strong - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Pathfinders: In the Company of Strangers - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping The King of Fighters - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping The Legend Is Born: Ip Man - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Extraordinary Measures - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping The Switch - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping Blue Valentine - no IMDb ID found
09:32:40 T:4068 M:1342062592 NOTICE: Trakt Utilities: skipping The Rite - no IMDb ID found
09:32:44 T:4068 M:1343258624 NOTICE: Trakt Utilities: Select: 3
09:32:46 T:4068 M:1343688704 ERROR: Error Type: exceptions.KeyError
09:32:46 T:4068 M:1343688704 ERROR: Error Contents: limits
09:32:46 T:4068 M:1343643648 ERROR: Traceback (most recent call last):
File "C:\Program Files\XBMC\portable_data\addons\script.TraktUtilities\default.py", line 122, in ?
menu()
File "C:\Program Files\XBMC\portable_data\addons\script.TraktUtilities\default.py", line 51, in menu
submenuUpdateSyncClean()
File "C:\Program Files\XBMC\portable_data\addons\script.TraktUtilities\default.py", line 71, in submenuUpdateSyncClean
syncSeenTVShows()
File "C:\Program Files\XBMC\portable_data\addons\script.TraktUtilities\sync_update.py", line 734, in syncSeenTVShows
for i in range(0, xbmc_tvshows['limits']['total']):
KeyError: limits
2011-05-11, 15:33
marcelbk Wrote:Here is the logFile.
Ok, manromen would know this better that I do, but the limitation with tmdb and movies might be an xbmc thing we'll look into it issue #48.
I've created an issue with regard to the fact that the error wasn't handled correctly #47 but unfortunately there isn't enough information provided in the log to determine the actual cause of the error. Maybe manromen can make some suggestions here.
2011-05-11, 17:10
Can't wait to see the friends list, I wish I could have a "recently watched by" on the home screen
2011-05-11, 17:14
TheMovieDB is just fine. I use this too. However XBMC returns IMDB id's (whether you use tmdb or imdb).
You could try to delete your library and scan again (please export your library before you do that, you have a backup then and you're able to import library again if it don't helps).
For the other error ... are you using a recent nightly build ? It looks kinda you use a nightly build of before April 4, 2011 ...
2011-05-11, 17:19
Hirs Wrote:Can't wait to see the friends list, I wish I could have a "recently watched by" on the home screen
Yeah this would be nice :-)
We could probably support some functions to get those kind of informations for skin developers (like tvtunes is called). But these features need to be supported (displayed) by the skins.
2011-05-11, 22:33
Manromen Wrote:TheMovieDB is just fine. I use this too. However XBMC returns IMDB id's (whether you use tmdb or imdb).
Yes. That's true, I'm using an older version.
I will try a new version and give you the feedback.
Thaks a lot.
2011-05-12, 00:10
One more question.
Does it work on 10.1 estable version?
