A few months ago i suggested the idea of making trakt utilities into a scraper
https://getsatisfaction.com/trakt/topics...diaplayers i haven't heard anything about that until now. I was now hoping that you guys could develop a way to scrape anime in a useful way using Trakt.
With the original name it is currently impossible to get anime's scrobbled with XBMC if there is more than one season. Even if you have regex syntax enabled only the episodes from the first season will appear. I've tried everything, from different regex codes to different scrapers, but nothing helps.
I really hope that Trakt utilities could possibly solve this problem. I am not the only one who would like that, there are thousands of people just like me who are having the same problems.
I just recently came across trakt and am hooked! I've installed the plugin and I'm loving it so far!
Only thing I can't seem to get to work is the rating system. Everything else works fine and even the test release runs pretty stable on my system. I've installed the latest nightly build and tried the stable and the latest test version. No difference. Any ideas?
Oh, and perhaps a tiny suggestion: isn't it possible for the plugin to automatically 'check-in' when you're watching a movie or tv show?
(2012-07-17, 02:30)dunpealhunter Wrote: [ -> ]A few months ago i suggested the idea of making trakt utilities into a scraper https://getsatisfaction.com/trakt/topics...diaplayers i haven't heard anything about that until now. I was now hoping that you guys could develop a way to scrape anime in a useful way using Trakt.
You might want to have a look at this thread over at sickbeard forum
http://www.sickbeard.com/forums/viewtopi...029#p21978 ...its a very big and active thread search it for the term xem.
(2012-07-14, 19:07)DejaVu Wrote: [ -> ]--EDIT
I've done a little digging around 'behind the scenes' and it seems as though there are a few issues with the latest versions of XBMC of late - hence the lack of updates - for which I apologies for my assumption that this is dead.
It appears that patience is key while the dev's scratch their heads to sort the issues out.
It sounds like a huge undertaking to make the changes, but hopefully will be a solution will be found for the official release of Frodo.
Keep up the great work fella's. We'll just have to wait til our Watched episodes can be resync'd with Trakt.
This is great to hear. Is that a Frodo issue? If so, any chance to have a version being added to the official repo for Eden?
Separate question - is it possible to have the add-on only sync the collection, but NOT the "watched status". Thanks in advance!
XBMC freezes then i try to sync seen movies.
Have anyone else had this problem to? Or is it just on my XBMC...
(2012-06-23, 04:08)neilperrya Wrote: [ -> ] (2012-06-18, 00:17)DejaVu Wrote: [ -> ]Keep getting Invalid Development API Key on mine using the Zip directly from Github.
Anyone else getting it?
Which is the offical version at the moment?
I keep getting this too..not sure what the deal is
And for me... Furthermore, keeps popping up, which is a hassle...
It says this is in the official repo now but I'm not seeing it.
Me neither. Running latest non frodo build.
It should show up under services, or if you search for it. Both methods showed it for me, simply called trakt version 1.0.0. If trakt utilities is working fine for you and scrobbling, no need to use this new plugin since it's pretty much the same type of scrobbler. Also, on one of my systems, I am running trakt utilities (with scrobbling off) and the new trakt scrobbler at the same time and it's working fine.
Ok found it. But not scrobbling.
Ill stick to the old one for now.
18:58:35 T:2958184448 ERROR: Python script "http://mirrors.xbmc.org/addons/eden/script.trakt/script.trakt-1.0.0.zip/default.py" does not exist
19:09:19 T:2961379328 ERROR: Python script "/Users/lowfi/Downloads/script.trakt-1.0.0.zip/service.py" does not exist
19:09:19 T:2889224896 ERROR: Texture manager unable to load file: /Users/lowfi/Downloads/script.trakt-1.0.0.zip/icon.png
Mac issue? Havent tried it in openlec or xbmcunbtu
It's some issue with having the old dharma plugin installed in eden, then updating to the new one. I did all my testing in osx and linux, but I didn't have the 0.1.5. dharma plugin installed. I had trakt utilities installed for all of my tests.
It seems like you need to unzip the file? The old plugin would also have to be completely cleaned out including removing any references in the autoexec.py file. I don't know exact steps yet though, so if anyone figures out a clean way to upgrade please let me know.
I have disabled the old one (0.6.5) activated the new one and filled in all necessary settings. Stopped xbmc, restarted. And it works!
So seems like i had to restart xbmc.
19:35:53 T:2956587008 ERROR: /Users/lowfi/Library/Application Support/XBMC/addons/script.trakt/nbhttpconnection.py:14: DeprecationWarning: the sha module is deprecated; use the hashlib module instead
19:35:53 T:2956587008 NOTICE: [trakt] loading script.trakt version 1.0.0
19:35:56 T:2956587008 NOTICE: [trakt] json url: /account/test/b6135e0f7510a44021fac8c03c36c81a17be35d9
19:35:58 T:2955980800 NOTICE: [trakt] [Notification Service] Waiting~
19:36:14 T:2955980800 NOTICE: [trakt] [Notification Service] message: {"jsonrpc":"2.0","method":"Player.OnPlay","params":{"data":{"item":{"id":777,"type":"movie"},"player":{"playerid":1,"speed":1}},"sender":"xbmc"}}
19:36:14 T:2955980800 NOTICE: [trakt] [Scrobbler] Watching: movie
19:36:15 T:2955980800 NOTICE: [trakt] json url: /movie/watching/b6135e0f7510a44021fac8c03c36c81a17be35d9
19:36:19 T:2955980800 NOTICE: [trakt] [Scrobbler] Watch response: {u'status': u'success', u'movie': {u'year': u'2011', u'tmdb_id': u'86820', u'imdb_id': u'tt1707391', u'title': u'4:44 Last Day on Earth'}, u'twitter': False, u'tumblr': False, u'facebook': False, u'message': u'watching 4:44 Last Day on Earth (2011)'}
19:36:23 T:2955980800 NOTICE: [trakt] [Notification Service] message: {"jsonrpc":"2.0","method":"Player.OnStop","params":{"data":{"item":{"id":777,"type":"movie"}},"sender":"xbmc"}}
19:36:23 T:2955980800 NOTICE: [trakt] watched: 16.5948798656 / 4909.0
19:36:23 T:2955980800 NOTICE: [trakt] json url: /movie/cancelwatching/b6135e0f7510a44021fac8c03c36c81a17be35d9
19:36:25 T:2955980800 NOTICE: [trakt] [Scrobbler] Cancel watch response: {u'status': u'success', u'message': u'cancelled watching'}
19:36:25 T:2955980800 NOTICE: [trakt] [Notification Service] message: {"jsonrpc":"2.0","method":"VideoLibrary.OnUpdate","params":{"data":{"item":{"id":777,"type":"movie"}},"sender":"xbmc"}}
19:39:40 T:2955980800 NOTICE: [trakt] [Notification Service] message: {"jsonrpc":"2.0","method":"GUI.OnScreensaverActivated","params":{"data":null,"sender":"xbmc"}}
19:44:33 T:2955980800 NOTICE: [trakt] [Notification Service] message: {"jsonrpc":"2.0","method":"GUI.OnScreensaverDeactivated","params":{"data":null,"sender":"xbmc"}}
19:47:34 T:2955980800 NOTICE: [trakt] [Notification Service] message: {"jsonrpc":"2.0","method":"GUI.OnScreensaverActivated","params":{"data":null,"sender":"xbmc"}}
20:05:20 T:2955980800 NOTICE: [trakt] [Notification Service] message: {"jsonrpc":"2.0","method":"GUI.OnScreensaverDeactivated","params":{"data":null,"sender":"xbmc"}}
20:08:24 T:2955980800 NOTICE: [trakt] [Notification Service] message: {"jsonrpc":"2.0","method":"GUI.OnScreensaverActivated","params":{"data":null,"sender":"xbmc"}}
Ok cool, I think the restart might have been the fix more than disabling trakt utilities.
Just for reference here are the version out there:
trakt utilities 0.6.5 (scrobbler + a lot more)
trakt 0.1.5 (dharma plugin, effectively replaced by 1.0.0)
trakt 1.0.0 (eden plugin, scrobbler only)
TU alone should work for scrobbling + more. If scrobbling doesn't work, then try...
TU + trakt 1.0.0 can run together, just disable scrobbling in TU.
In all cases, trakt 0.1.5 shouldn't be used in eden+ anymore since 1.0.0 does the same thing just better
Im sure these options will find their way in the "official" (?) plugin eventually?
