Just thought I'd create some intrigue
, I've just finished coding up a pile of new features ready for v0.6.0
, and it should be released mid next week. Manromen took a bit of a break with this release, he was busy but helped out and was as responsive as ever to any questions we all might have had, he should be back for the next release (unless of course I cant help myself and I get carried away coding features for another version
and have to release that).
So to the awesome features, how about we start with a big one
. Experimental core scrobbling support, yes you read right, for v0.6.0 I decided to pull forward making it possible to run Trakt Utilties without the official trakt add-on
; we had always planned to do this but not really at this stage. This feature is very new, and I'm sure there are one or two bugs left in it and you might even have some ideas on how to make it function better. For those of you who don't know what scrobbling is, or those who don't know the term, scrobbling is telling trakt that your watching something, as your watching it.
P.S. This was also going to be my chance to see how many smilies I could use and still have it make sense
but it seems I'm limited to six, so I have to stop adding them now.
Finally got around to adding the tags on the TV Shows in the TV Show windows. This should make the next feature more useful
Added context menus to the TV Show and Movie windows (the watch-list, recommended and trending windows). This menu adds options to rate any item shown, or to play a movie (hopefully soon TV Shows too) and my personal favorite to add/remove an item to/from your watch-list. For instance if your looking through the recommended Movies and you see one that you like the look of, but as the tags indicate you yet don't have, you can add it to your watch-list without even leaving XBMC. That way you don't forget that you want to watch it.
The rating dialogs have been updated and you can now 'unrate' any item that has a rating on it, and it will tell you what your have rated the item if you have already done so.
Another feature is credential verification, from this version on when trakt starts up it will instantly check that your trakt credentials are present and correct, if they are aren't it will tell you your a very bad person but then it will take you to the settings screen where you can fill them in / fix them.
That's all for now, if I notice I've missed something major I'll edit this post otherwise you can find the complete changelog at
https://github.com/Manromen/script.Trakt...ngelog.txt
I really can't wait to use these new features... oh wait, I don't have too; and it won't be long for you either. Unless of course your using stable releases, in which case, it might be several weeks. Eh that's the cost of stability.
