2012-09-04, 22:12
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103
2012-09-04, 22:14
(2012-09-04, 22:12)seadog Wrote: [ -> ]Are you calling movie sync from the trakt menu or using the "run on startup" feature?
Run on startup.
2012-09-04, 22:19
Ah ok then, I'll fix that tonight and make sure I fully test it then hopefully push it in a few hours
2012-09-05, 03:18
2012-09-05, 10:15
(2012-09-05, 03:18)seadog Wrote: [ -> ]I just tried the autosync under Frodo and it definitely works (using the latest commit on the develop branch)
I am using Eden final...
2012-09-05, 15:11
(2012-09-05, 10:15)tripkip Wrote: [ -> ](2012-09-05, 03:18)seadog Wrote: [ -> ]I just tried the autosync under Frodo and it definitely works (using the latest commit on the develop branch)
Ah ok this bug's fixed in my local repo, just doing some stuff and it'll be pushed in a short while
2012-09-05, 17:47
Just so everyone knows, in order to stop spamming this thread with my fork I've started a new topic (and renamed the fork), the post is at: http://forum.xbmc.org/showthread.php?tid=139839
2012-09-06, 12:34
Hi, i had my library synchronized with trakt, but due to a problem i had to erase it (deleted the mymovies60 from userdata).
Now i have to manualy import my sources and my question is:
is there's an option that trakt can synchronize my xbmc library (watched, progress, etc)?
thanks in advance
Journeyman
thanks in advance
Journeyman
2012-09-06, 13:45
For a different problem i have enabled debugging and noticed this for TU
Quote:13:24:03 T:140130945447744 DEBUG: ADDON: cpluff: 'Suspicious plug-in descriptor content in /storage/.xbmc/addons/script.TraktUtilities-0.6.5/addon.xml, line 14, column 5 (ignoring unexpected element res and its contents).'
13:24:04 T:140130945447744 INFO: ADDON: cpluff: 'Could not read plug-in directory /usr/lib/xbmc/addons: No such file or directory'
2012-09-11, 08:25
Ok i'm new to trakt.tv...
Though i'm not sure what to take for xbmc and ipad...
So far as i can see, i see 3 addons for xbmc
- The original one trakt.tv addon
- This one , trakt utilities
- And latest? one "traktr"
which one do i get now?
if i get this one "trakt utilities", do i still need to install the original one then?
What are the differences?
I want to rate movies too.. as i can see, the original one cant do that?
And the latest one only has frodo compability? Are those the only differences?
Also for ipad.. what app do i take?
Thanks !
Thanks !
2012-09-11, 14:47
I am unable to authenticate to trakt via xbmc. I am certain I am using the correct username and password, I have tested it successfully on the trakt.tv website.
I am running the default windows firewall, but I don't see anything in any logs indicating a restriction. Does this connect over a port other than 80?
Here's a snippet of my log.
I changed my password from one with special characters ($:!) to one with just alphanumerics and authentication continues to fail. I have tried using both http and https in the settings, both fail.
08:42:27 T:5300 NOTICE: Starting XBMC (11.0 Git:20120321-14feb09), Platform: Windows 7, 64-bit (WoW) Service Pack 1 build 7601. Built on Mar 21 2012 (compiler 1600)
08:42:28 T:3912 ERROR: C:\Users\Keegan\AppData\Roaming\XBMC\addons\script.trakt\utilities.py:19: DeprecationWarning: the sha module is deprecated; use the hashlib module instead
import sha # Python 2.5 and earlier
08:42:28 T:3364 NOTICE: -->Python Interpreter Initialized<--
08:42:28 T:3912 NOTICE: [trakt] loading script.trakt version 1.0.1
08:42:28 T:3912 NOTICE: [trakt] json url: /account/test/(removed)
08:42:28 T:3912 NOTICE: [trakt] traktQuery: Error: failed authentication
08:42:29 T:5196 ERROR: CRemoteControl::Connect - failed to connect
2012-09-11, 15:23
(2012-09-11, 08:25)Skank Wrote: [ -> ]Ok i'm new to trakt.tv...
Thanks !
Essentially as far as I know there are 3 choices, script.trakt which supports scrobbling, eden and frodo but not rating/syncing (and is in the official repos) and can scrobble streaming videos, script.traktutilities which supports only eden, can sync movies/videos (so if you lose your xbmc library you can repopulate play counts/watched statuses from trakt) and can do simple ratings (i.e love/hate/unrated) and my fork traktr which supports eden and frodo, simple/advanced ratings and can also sync (and the next release will include support for scrobbling streaming video)
2012-09-11, 15:30
(2012-09-11, 15:23)seadog Wrote: [ -> ](2012-09-11, 08:25)Skank Wrote: [ -> ]Ok i'm new to trakt.tv...
Thanks !
So basically i should chose trakt if i want to rate the movies i saw..
Cause i just installed traktutilities, watched a movie, but i couldnt rate it, the only thing i could do is love/hate and click the unrate button...
Another thing that i saw using traktutilities was that my library i synced wasnt right
In xbmc i have 372 movies, and in trakt it showed all movies : 368 movies..
i dunno why
Also when i played the movie, at the end of it (i watched it completely) it gave me an error: that to rate.. runtime was too short (trailer?)
i dunno why?
then the box came to like/dislike/unrate...
and scrobbling means "displaying what you are watching in real time right?
2012-09-11, 15:34
Yeah scrobbling tells traKt what you're watching as you watch it and then sets it as just watched when it finishes, if you want 0->10 ratings though I don't think another addon offers it except for mine (traktr)
2012-09-11, 15:51
(2012-09-11, 15:34)seadog Wrote: [ -> ]Yeah scrobbling tells traKt what you're watching as you watch it and then sets it as just watched when it finishes, if you want 0->10 ratings though I don't think another addon offers it except for mine (traktr)
then im going for yours
