Full Version: Remote mouse move events
Hello all,
I am writing a remote for XBMC in C++ running on Ubuntu 10.04 on the latest source code.
The xbmcclient.h code works well with various buttons that I tried, but the CPacketMOUSE sends the cursor to 0,0 (upper left corner) regardless of the X,Y parameters passed. I tried with and w/o a UID parameter.
Is any initialization required? Is there a bug in the library client code maybe?
Thanks,
Michael
CPacketHELO HeloPackage("Example Mouse", ICON_PNG, "../../icons/mouse.png");
  HeloPackage.Send(sockfd, my_addr, UID);
  sleep(5);
  for(int i = 0; i < 65536; i+=2000)
    CPacketMOUSE mouse(i,i);
    mouse.Send(sockfd, my_addr, UID);
    sleep(1);
    printf("%d\n",i);
  // BYE is not required since XBMC would have shut down
  CPacketBYE bye; // CPacketPing if you want to ping
  bye.Send(sockfd, my_addr, UID);
bump. any help?
I think I have found the issue.
xbmc/network/EventClient.cpp
CEventClient::GetMousePos() uses g_graphicsContext.GetViewWindow() which is only available while a video is playing, instead of g_Windowing.GetViewPort()
Should I commit the fix?
Sure, commit the fix to your github and send a pull request. Make sure you clearly describe the problem and your chosen solution.
Cheers,
Jonathan
