Full Version: Lock screen to portait.
Is there anyway I can get the screen/remote to lock in a vertical portrait position?
I find it annoying when it switches from vertical to horizontal or vice versa particularly if I've just picked the phone up.
If you use the gesture mode it will be in portrait only.
Otherwise you will have to disable the rotation in Android.
