Full Version: Confluence issue with ATV2
Ive noticed a couple of issues wih using the confluence skin with the atv2.
First, when I update xbmc to a nightly build confluence no longer has the option to switch between a vertical or horizontal home menu.
I fix this by using WinScp and just replacing confluence with another copy from my Revo.
The second issue I am having is with the recently added movies.
At first they wouldnt show on the 'movies' main screen.
Jezzx showed us how to fix that by changing 'true' to 'false' in the code.
Now, the problem is the box shows and lists the last 4 movies added, but usually the coverart shows in that box.
Using the nightly builds, the coverart no longer shows.
The official build didnt have this problem.
The 4/1 nightly does.
1) was deliberately removed because it was a logistical nightmare to maintain it
2) is a problem with the script changes to the way xbmc library works broke it you can get a working version from here http://forum.xbmc.org/showthread.php?tid=97098
Thanks for the help.
Sorry to hear about 1. because I love the ability to choose.
